Headlights act strangely
Old Jan 7, 2005 | 09:42 AM
prs62's Avatar
prs62
St. Jude Donor '05-'07
Default Headlights act strangely
I was just putting air in the front left tire using a small electric compressor. When I turned the compressor on, the headlights came on. When I turned the compressor off, the headlights went off. Only happened once and I could not recreate it. Has something like this happen to any of you? My MN6 was locked and in reverse. -JR
Old Jan 7, 2005 | 11:12 AM
Boozman's Avatar
Boozman
If you had your fob in your pocket it could have been pushed to unlock the doors????
Old Jan 7, 2005 | 11:13 AM
bangbgC6's Avatar
bangbgC6
I've had similar mystical happenings only to discover this is the case.
Old Jan 7, 2005 | 01:20 PM
prs62's Avatar
prs62
Default Mystery sloved
Thanks. Apparently that is what happened. The fob was in my pocket. Thought I was going -JR
Old Jan 7, 2005 | 01:35 PM
LS WON's Avatar
LS WON
Default Your headlight switch is on auto so if it is dark it will come on
Probably not the cause of your problem but who knows. There must be a way to have the headlight on manual so when you start Corvette your lights don't come on if it is dark. By Owners choice...
Old Jan 7, 2005 | 10:14 PM
Low12s's Avatar
Low12s
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
Good luck
Old Jan 8, 2005 | 10:50 AM
Buster1's Avatar
Buster1
Glad to hear it was only the FOB. Now if you start hearing your C6 talk to you...you may have a problem there.
Old Jan 8, 2005 | 11:11 AM
Vette_DD's Avatar
Vette_DD
Not if you have OnStar and push the phone button.
To Headlights act strangely
