many of us have noted that sometimes it is impossible to shift
into 1st gear from a stop in a C5 or C6. page 2-26 of the C6
owners manual has the following note that indirectly implies
that GM considers this an inherent characteristic of the tranny
design:
"If you come to a complete stop and it is hard to shift into first,
put the shift lever in neutral and let up on the clutch. Press the
clutch pedal back down. Then shift into first."
Cycling the clutch as suggested works perfectly, just as it did in the C5.
some have theorized that this is a synchro issue and have solved
it by using other brands of transmission fluid, but personally id be
surprised if that actually makes it stop. for me its infrequent enough
to ignore.
design:
to ignore.
When stopped, the driven gears are stopped. With the clutch depressed, after a couple of seconds, the driving gears are stopped. If the synchro teeth for the two sets of gears don't happen to be aligned, which is fairly likely, then it won't go in gear. This is no different than any other manual transmission. Momentarily letting out the clutch will cause the drive gears to spin, and gives you another chance to find alignment, especially if you attempt the shift before the driving gears come to a full stop again.
Changing the transmission lube won't alter this simple geometric arrangement. Shifting to first *before* you come to a complete stop, however, will avoid this issue entirely.
Yeah, I was trying to figure out how transmission fluid would affect the issue. Also, as you point out this problem is not confined to Vettes.
Yep. That's the bottom line. The only sure way is to have the car in 1st when you come to a stop. As long as you roll to a stop with the shifter in 1st (clutch pedal can be on the floor), you'll never have an issue with getting it in 1st. This problem occurs when you drift to a stop with the shifter in neutral.
I agree, I've been driving manual transmissions for 30 yrs and this has always been the case. There is nothing wrong with the transmission, it is simply they way they work. While waiting for a light, I'll usually put it in first for a sec then put it in neutral. It will typically go back into first when I'm ready to go with no problem.
design:
to ignore.
Row the boat to re-align the gears and you will be good to go I also recommend Royal Purple syncromax as its made a bit of the notchiness go away.
My C6 does it and my Acura Legends did it as did my Bimmer and Supra. It is the alicnment issue mentioned earlier. Either clutch it in neutral or go to second quickly (clutch remains depressed) and it'll go. Just needs to realign. Not a tranny fault.
With my Z06, I found it was worst when shifting from 4th to 1st after a stop. If I moved the lever through either 3rd or 2nd (without releasing the clutch), it was fine. In addition, the issue got much better after some wear loosened things up.
just for the record I wasnt implying that this wasnt normal, or was
in any way unique to the C5/C6. I agree with everything thats
been said so far. just figured id mention it since it
was referenced in the manual where it was easily overlooked.
I posted it in the C5 section as well.
I've been driving clutch cars for over 30 years (not necessarily correctly) I notice most people put their car in neutral when stopped then shift to first. I always keep the clutch pedal pushed all the way to the floor and keep the car in first until ready to go. Is this a bad thing? I have never had to replace a clutch, but then I tend to trade cars before 50k miles also. Just wondering.
Depending on how long the light is, and whether I'm first in line or not, I do it too. It puts a little more wear on the throwout bearing, and your leg, but it is otherwise harmless.
It could be, if there are pedestrians crossing in front of you, and a bee flies in your car or you're otherwise suddenly startled by something and accidently let your foot off the clutch pedal.
From: San Antonio Texas - Any sufficiently advanced technology is indistinguishable from magic
design:
to ignore.
Killed a throwout bearing on my 73 vette by keeping the clutch in at lights, too often.
Also a safety factor-if you get bumped in the rear -your car will launch forward if your foot slips off the clutch. For the sake of the bearing and safety ,best to depress clutch when light changes or just before.
