An improved base C6!!!!!!!
Old Jan 19, 2005 | 10:48 AM
ivan111's Avatar
ivan111
Default An improved base C6!!!!!!!
The new Corvette C6 has arrived in the dealers’ showrooms! geigercars.de (Truderinger Str. 265, D-81825 München, Germany, Tel.: +49 / (0) 89 / 42 71 64 13, Telefax: +49 / (0) 89 / 42 71 64 10, e-Mail: info@geigercars.de , Website: http://www.geigercars.de ) now offers a sporty tuning program for the American sportscar. While the bodywork remained untouched for the first stage, geigercars already offers options for engine, suspension, brakes, tires and interior.
While a capacity increase of the Corvette’s V8 engine to about seven litres of displacement is already in the stage of development, the geigercars.de experts found extra horsepowers on the periphery of the engine. To achieve a power increase from standard 400 hp / 294 kW to 445 hp / 328 kW they developed a free-flow intake air guiding with sport air filter, a high performance exhaust system inluding special manifolds, steel bed catalysts and four large chrome exhaust tips, a lightweight flywheel and a special mapping for the ECU. The performance kit is available starting from 8,040 Euros.
The engine tuning makes the Corvette C6 even more agile and doesn’t only convince with quicker revving up but also with higher road performances: The sprint time from 0 – 100 km/h is reduced to 4.0 seconds, maximum speed is increased to 307 km/h.
To be able to always safely control these road performances, geigercars.de offers two different high performance brake systems for the Corvette C6. The front axle system, which is offered for a retail price of 4,175 Euros, consists of vented and cross-drilled 355 x 32 mm brake discs and four-pot aluminium fixed calipers. For another 3,595 Euros the geigercars.de sport brake system can be extended with 345 x 32 mm discs and four-pot aluminium fixed calipers on the rear axle.
geigercars.de also offers different options for the suspension tuning of the new Corvette. The range reaches from a lowering kit that lowers the coupe by about 30 millimeters over a geigercars.de sport suspension with stiffer set-up gas pressure shock absorbers up to sport sway bars on front and rear axle.
Wheels make a car and as a result geigercars.de offers a very exclusive wheel/tire combination for the Corvette. The multi-piece chrome wheels of the dimensions 9.5Jx20 front with 255/30 ZR 20 tires and 10Jx20 rear with 305/25 ZR 20 tires perfectly fill the existing space inside the wheel houses. The geigercars.de set of wheels with tires and the suspension tuning kit are charged with 10,710 Euros.
Of course geigercars.de also offers exclusive interior appointments for the cockpit of the Corvette C6 up to the masterly handcrafted full leather trim in every imaginable color and design.
The handling of this C6 should be like is in rails.......
Old Jan 19, 2005 | 11:17 AM
WhiteDiamond's Avatar
WhiteDiamond
St. Jude Donor '15
Wonder what they are using to tune the PCM?
Todd
Old Jan 19, 2005 | 11:27 AM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
Oh good, more air intake and exhaust improvements.
Old Jan 19, 2005 | 12:13 PM
RAP's Avatar
RAP
kinda expensive.......but those of us in Europe have limited options I suppose.
Old Jan 19, 2005 | 12:32 PM
Mighty-Mouse's Avatar
Mighty-Mouse
Since it seems that the Z06 is making it to Europe why not just get that:
http://forums.corvetteforum.com/showthread.php?t=989312
Old Jan 19, 2005 | 07:57 PM
ivan111's Avatar
ivan111
Here are some pics of the yellow C6 with the mods:
http://www.geigercars.de/
To An improved base C6!!!!!!!
