[Z06] Who has had their Z06's alignment done?
Curious if any Z06 owners have had their Z06 alignment spec's checked and or changed?
What where your results?
I had my C6 checked out and the spec's where no where near factory at 13k miles. When a local tuner shop did a setup halfway between factory and a typical track setup, it felt like a totally different car. Much more planted.
Anyone with similar results?
Andi
Corvettes do not come from the factory with a good alignment. It is fine for tire wear but very poor for performance. Be careful not to add too much negative camber on the wide tires for street driving. The insides will wear out. If you complain within the first 7,500 miles GM will cover the alignment most of the time.
Tire wear shouldnt be that much of an issue or else you got the wrong car IMO..please take no offense. I would get rid of Toe-in unless you are always doing 150+mph. Toe out gives better traction when turning.
