[Z06] Will this Eliminate Glove Box and Center Console Heat...
I am planning on installing new headers soon looking around for new stuff for our Z06's I ran into this heat sheild made for C6 Z06's http://www.pfyc.com/store/merchant.m...ory_Code=C6NEW
What do you all think?
Might want to look into a coated aluminum tunnel plate. I put one on my C5Z a couple weeks ago and noticed a big difference, it cost $240 shipped from elite engineering.
Originally Posted by Z-Jay
This should be a bigger topic I seen many threads on the heat issue but no one giving a fix like these....
St. Jude Donor '09
Originally Posted by chris36053
I tried the coated tunnel plate on my regular C6 and it only reduced the temps slightly. The tunnel plate works better to stiffen the car then it does to reduce heat. I looked into the Heatmaster but was reluctant to spend the money until i hear from other C6 owners that are using it.
Tom in WF
Originally Posted by nag1945
Rather than put in a shield why don't you just install 160 thermo and adjust fans mine runs 172 all day and no more heat and makes for a better program
Time to spill coolant all over the garage floor again.
Originally Posted by Foosh
Perhaps it's not a bigger topic, because it's a non-issue for the vast majority of us.
I could honestly say it's not a Huge issue but when I put my Cel Phone to charge where GM made a perfect spot to do so and I took it out about 45mins later it was like a hot piece of coal. I just thought that if there was some products out there that some forum members found that actually worked that it would be great to post and disscuss the results. I am a bit concerned about using SS Plate due to the extra weight so I was wondering how well the Alum Coated does compared to the Heat Shield. In any event as much as it is a non issue compared to how awesome this car is it's still a little issue that if I have headers installed I can kill two birds with one stone
Originally Posted by Mako7
Ah, I posted the fix many times! BeCool under car tunnel shield and interior heat insulation. [Only for those who care about these things].
Originally Posted by forhamilton
160 degree thermostat being installed now. I'll let you know afterwards.
In addition, I think the engine is designed to run at 190 (lower end of range) as a normal operating temp. Anything lower isn't necessarily better for the engine.
I don't understand how a lower temp t-stat could significantly alter the amount of tunnel heat. Having the fans come on 20-30 degrees earlier, shouldn't change the operating temp of the engine when fully warmed up. It just means the thermostat opens a little sooner when cold. The rest of the drive train still experiences the same heat.
The heating of the center console is not bad when your under way, but if you get stuck in stop and go traffic with these cars you will have excess heat in your center console area and cup holder.
A 160 t-stat is not going to do a thing for you. Your exhaust temps are the same whether your running a 160 or 190 t-stat.
In addition, you may actually be causing premature wear by using a lower temp stat. You are causing your engine to take longer to warm up, and we all know most of the wear on an engine happens at start-up through warm-up. It needs to be at least at 190 for proper lubrication, and the sooner that happens the better.
Get Some!
Yes, that type of insulation works very well. A friend of mine took the insulation blanket that goes around large diesel turbos and did this in his C5 Z06 with LT headers. The heat reduction was well worth the effort. Shop around some that price is high IMO.
I asked one of the GM engineers (chassis) I've had email contact with about these heavy tunnel plates and asked him what they would do, he said, "Add mass."
