C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Nitrogen filled Tires.
Old 05-03-2006, 01:56 AM
Z-Jay
Z-Jay's Avatar
Default Nitrogen filled Tires.
Nitrogen filled Tires. What do you all think of it?
Old 05-03-2006, 02:00 AM
NORTY
NORTY's Avatar
Oh God,not again!
Old 05-03-2006, 02:22 AM
ZeeOh6Nut
ZeeOh6Nut's Avatar
Default Liquid State?
Sounds like your tires would be really cold. You saw what happened to the T1000 in T2!
Sorry, couldn't resist.
Old 05-03-2006, 02:28 AM
LS WON
LS WON's Avatar
You must shop at Costco
Old 05-03-2006, 09:09 AM
Short-Throw
Support Corvetteforum!
Short-Throw's Avatar
Old 05-03-2006, 09:32 AM
runamuk
runamuk's Avatar
Cruise-In V Veteran
St. Jude Donor '04
It's only for suckers or people who fly their airplane at high altitudes
Old 05-03-2006, 09:56 AM
grady
grady's Avatar
One of our local quickie oil change stores had a sign out last week for nitrogen filled tires for only $19.95
Old 05-03-2006, 09:57 AM
dietrich
dietrich's Avatar
It only make a difference on race car. There is no point to do this with road car.
Old 05-03-2006, 09:58 AM
LTC Z06
Get Some!
LTC Z06's Avatar
Air is 70% nitrogen, if your tire place or any where you stop to add air has a good water/air separator then you are getting dry air, which is the main benefit of nitrogen only, it is more processed and very dry. They don't purge your tire though so it will have at least one atmosphere of moisture laden air in it regardless.
Old 05-03-2006, 03:26 PM
bernrex
bernrex's Avatar
Have you heard about Hydrogen-filled ones ? They are lighter ....
Old 05-03-2006, 03:38 PM
Painrace
Painrace's Avatar
In the early days or racing (Yes, I am that old) we took an air compressor. The air going into the tires was heated and the last tire you put air into had more hot air than the first. This affected the roll out and made the car inconsistant from session to session depending on temperature and the time of day. We soon learned that taking nitrogen bottles was easier and nitrogen in the tires gave more consistant roll out. The nitrogen also worked well to operate air tools. Using nitrogen on a street car is like turning the radio off so there won't be as much power drain and so the car will go faster!
Spend your $$ on something else like a cold beer.
Old 05-03-2006, 05:59 PM
Exterminator
Exterminator's Avatar
Yes, have you heard about the Hindenburg? It was filled with hydrogen too!
Old 05-03-2006, 06:13 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Less moisture and it works on race cars to keep pressure more stable as heat builds up. Like stated above you need to purge the tire 3-4 times to get most of the air out. Doubt anyone selling tires does that.
forhamilton
forhamilton's Avatar
And the best performance with hydrogen filled tires would be with an exhaust similiar to the Vipers.
Old 05-03-2006, 06:15 PM
John Shiels
Less moisture and it works on race cars to keep pressure more stable as heat builds up. Like stated above you need to purge the tire 3-4 times to get most of the air out. Doubt anyone selling tires does that. I have a small bottle 4' to take to the track. Then you rent a huge one for cheap 40-50 bucks a year and keep it at home for the initial filling. I need to find out if I can transport it legally to the track. Then I would use the small bottle to adjust tires at the track.
Old 05-03-2006, 07:37 PM
xsiveone
xsiveone's Avatar
Using nitrogen instead of compressed air has distinct advantages, which lead to immediate benefits for the vehicle owner.
1. It has more mass, so it migrates through the tire three to four times slower. The result: Tires hold their psi longer.
2. It runs about 20% cooler. Less heat results in less tire degradation.
3. It drastically reduces oxidation on the rim and inner-liner (nitrogen systems almost totally eliminate oxygen -- the cause of oxidation -- from the mix).
4. It is environmentally safe.
Nitrogen is an odorless and colorless gas that makes up more than three-quarters of the air we breathe, which explains why it is environmentally safe. It is relatively non-combustible, non-flammable and non-corrosive, as opposed to oxygen, which in its natural form can be all three of the above. Oxygen makes up close to 21% of the atmosphere.
Old 05-03-2006, 09:26 PM
waltershu
waltershu's Avatar
I have Nitrogen in my tires, and i love it.better ride Quality!!!!!
To Nitrogen filled Tires.
Old 05-03-2006, 09:30 PM
CB1953
CB1953's Avatar
That poor old dead horse is about to get beat again....
Old 05-03-2006, 11:53 PM
ogduncan
ogduncan's Avatar
hmm has anyone tried helium.
Old 05-04-2006, 12:03 AM
Westwopper
Westwopper's Avatar
Default Nitrogen
John's right, You probably would have to purge the tire twice to get below 20% humidity in the tire. This will give you more controled pressure growth when your at the track.
You will have to add air to your tires less often if you use Nitrogen, but I'm not sure how much of a difference there is.
I'm not sure that cooling the tire is a big benefit. It probably comes from people running the correct pressure.
Unless some one put it in my street tires for free, I wouldn't waste my money.
BTW, I fill my tires with a Propane... Makes the car faster off the corners and great for grilling later on.
Quick Reply: [Z06] Nitrogen filled Tires.
