[Z06] C6 Front License Plate Bracket
#282
Just finished installing my removable bracket along with the matching color frames. Very nice!
The only thing I would suggest is that you explain in your directions why to keep the bracket about 1/8 inch "forward". Though I read the instructions, I keep hearing about now tight a fit the bracket becomes, as if it fits seamlessly with the car (which it essentially does). But I guess I didn't factor in the 1/8 inch and it was a BEAR to get the bracket reinstalled on the posts after that. Mine is no longer a removable bracket (by default )
Nice product though!
#283
#285
#289
St. Jude Donor '12
This is exactly what I was wondering when I saw the 'position' of the bracket over the grill area blocking part of air flow. I live in Texas where it's already real hot....now I wonder if this will cause any problems for my Z's temp.....knowing it already gets warm. I do NOT track the car. Just some spirited driving every once in while.
#291
#292
Front License Plate rubs
I use the Top Flite bracket on my Texas car. The ONLY thing that I don't like is that the bottom corner edges of the license plate rubbed-off 2 small areas of paint on the lower lip (below the grille opening). Probably my fault for not bending the lower edges of the plate forward away from the paint sooner! However, including a short piece of self-adhesive rubber strip material with the kit and a caution to check clearances after installation (bending the license plate lower corners outward) would have kept me from using my Atomic Orange touch-up paint!
#293
In Stock!
The Top Flight Reproductions C6 front license plate bracket is the best looking mount available. It follows the contour of the front bumper. Installs easily without lifting the car. Requires no drilling for attachment like some others do. Our bracket is priced considerably lower than other after market solutions and is made in the USA
All three Top Flight Reproductions front license plate brackets are in stock and ready to ship. Visit our website at www.topflightrepro.com or call 781-279-1279 and ask for Ray.
C6 Z06/ZR1 Removable Front License Plate Mounting Bracket
#295
St. Jude Donor '12
Hi Folks, Ray and I have decided that it was time for Top Flight Reproductions www.topflightrepro.com to become a Forum Vendor. For those of you who live in states that require two plates and are interested in a front mount, Top Flight Reproductions has a permanent and removable mount for the C6 and a C6 Z06 removable mount as well . We also sell the GM colored license plate frames which really dress up the front mount. The Installation is very easy, requires no lifting of the car. We have had this product out for over 2 1/2 years now and the customer satisfaction has been fantastic. We appreciate all the nice comments from you forum members who have purchased these products along with inputs for making our product better, we thank you. For those of you who haven't heard of us, check out our website at www.topflightrepro.com or give us a call at 781-279-1279 and ask for Ray. We look forward to hearing from you.
In Stock!
The Top Flight Reproductions C6 front license plate bracket is the best looking mount available. It follows the contour of the front bumper, easy to install, and is priced considerably lower than other after market solutions.
In Stock!
I need one of these for my 2010 Z06.....the stock mount came off (dealer installed it) after I mounted the license plate to it.....luckily it came off in my garage....I first thought it came off on the highway....anyway....I need one....i suppose I will try and order it today while I'm at work....gotta get ready for work and go, now...welcome to site....Tim N Texas
#296
#297
i have a pet peeve to bring to your attention, i bought your bracket almost a year ago and i took it off because it doesnt fit properly. the top plate that sticks to the underside of the bumper hole is too deep and hits the grille. it causes the plate to stick out in front of the bumper about 1/2 inch.
also I ended up getting just the bracket because i was under the impression the frame came with it! only to find out it was an extra 100 some bucks!
if you want my opinion the plastic and painted frame is worth more money i am sure due to manufacturing costs than a bent peice of metal with double sided tape! i would have been happy to buy the frame and make my own bracket.
#298
Peter C.
#299
In Stock!
#300
I have a question - when mounting the license plate to the bracket, does the plate have to be bent first to fit the bracket or will the mounting screws draw the plate into place snug against the bracket?
Thanks!
d
Thanks!
d
