C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 2006 C6 Z06 Twin Turbo with Pictures and Dyno Graphs
Old 12-09-2006, 12:01 AM
macsperformance
macsperformance's Avatar
Default 2006 C6 Z06 Twin Turbo with Pictures and Dyno Graphs
I thought some of you guys might enjoy this, and wanted to share.
Stock LS7, Twin GT35R Turbos, Lingenfelter 100mm MAF, Modified BB Exhaust (catback) 5.8 psi of boost!! The car only had 1,404 miles on it The Torque output was 631 ft/lb at 3600 RPM.
I do not think many people have done this set-up with these turbos yet. I was impressed with the car!
The customer was from Alabama but the car was put together by Walker Morgan from Morgan Performance Fabrication http://www.mpfab.com
He has some of the best fab/welding skills I have seen. Super clean work!
The car made a 58X HP pull but got heat soaked by the end of the day! I tuned the car with HP Tuners Software.
I will try to get a video of one of the pulls up later!
Horse Power and Torque
The same run showing the boost pressure.
An estimated Flywheel output of the car done in the Dyno Dynamics Shoot out mode
Chris Macellaro
Old 12-09-2006, 12:05 AM
LTC Z06
Get Some!
Support Corvetteforum!
LTC Z06's Avatar
No pic of the engine and turbos
Old 12-09-2006, 12:14 AM
macsperformance
no, sorry friend
The engine looks stock from above, the car has to be on a lift to see the turbos, so I did not get any.
Chris Macellaro
Old 12-09-2006, 12:21 AM
1985 Corvette
1985 Corvette's Avatar
Wow. That yellow is something else.
Old 12-09-2006, 12:41 AM
Vindication
Vindication's Avatar
yikes....GT35R's? Why are you only boosting 5 psi with these Turbos???? They need more boost. Get the bottom end done and boost 14 pounds then.....
Old 12-09-2006, 12:51 AM
0Louis @ LG Motorsports
Former Vendor
Louis @ LG Motorsports's Avatar
Glad you guys got it worked out! I had been trying to help Walker sort things out with the MAF issues, I know that has tested his patience to the max
Excellent setup, VERY clean, professional fabrication!
5#s is about all I would push the stock pistons to. A forged, lower compression piston and stronger rod would allow more boost, but Im sure the car is a handful now, what is it going to do at 15#s? I bet it spins a dynojet to a much better number. Dyno Dynamics are a little conservative.
Congrats guys
Louis
Old 12-09-2006, 12:58 AM
macsperformance
Congrats guys
Louis
Louis!
Thank you for all the help and kind words. Your 100% correct; Walker worked very hard on the car and did one heck of a job! He deserves all the credit! Great guy and great work!
thank you Louis
Chris Macellaro
Old 12-09-2006, 01:53 AM
ElisTwoCents
ElisTwoCents's Avatar
St. Jude Donor '05-'06,'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Nice car
Old 12-09-2006, 03:50 AM
Icebourg
Icebourg's Avatar
Thanks for the info!! Great pics!!
Old 12-09-2006, 06:16 AM
Verrückt
Verrückt's Avatar
Peak power at 5400 RPM?
Why is there such a drop off on the top end?
Old 12-09-2006, 08:10 AM
WeaponsGradeTorque
WeaponsGradeTorque's Avatar
Some Turbo's tend to do this but this is because the turbo make such monstrous mid range torque. The car still wound up making amazing power.
The aftermarket toys coming out for this car are getting better!
Old 12-09-2006, 09:26 AM
macsperformance
Thank you for all the comments everyone!
Peak torque occurs very early in the pull. On the street lugging the car in 3rd at 1500 RPM the car bolts forward at the slightest provocation of the throttle. It is simply amazing. The end of the graph actually falls off a bit more than it should. There is an RPM discrepancy at the very end of the graph due to the tires slipping from about 150 mph to redline at 157 mph. I used the dyno's roller speed to get the RPM. If I had used an inductive pick-up on the car we would not have had that problem. All the other RPM points look to be correct; just not the end of the run. That was a little to fast for me anyway... even sitting still on a dyno.
thank you
Chris Macellaro
Old 12-09-2006, 10:38 AM
UTVOL06
UTVOL06's Avatar
holy smokes batman!
that thing must be hella fast...I wonder what kind of 1/4 mile times you will get?
Old 12-09-2006, 01:23 PM
06Z0606
06Z0606's Avatar
Originally Posted by UTVOL06
holy smokes batman!
Are you from California bay area? I thought we were the only people to say hella. Just curious
Old 12-09-2006, 01:35 PM
DDSLT5
DDSLT5's Avatar
He is from Co, his name is Eric.
Old 12-09-2006, 02:03 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I'd love to see some pics of the turbo setup etc.
Old 12-09-2006, 03:51 PM
Verrückt
Verrückt's Avatar
At those horsepower levels, each one of those GT35's will be pushing about 40 lbs per minute. Granted such low pressure ratios aren't exactly efficient...but the turbos aren't going to be running out of breath either.
At first I thought it might be a tuning issue, but the explanation given of the rollers slipping makes sense too.
I'm not being negative here, things just didn't look right to me. Carry on.
To 2006 C6 Z06 Twin Turbo with Pictures and Dyno Graphs
Old 12-09-2006, 07:11 PM
keagan
keagan's Avatar
get that thing on a lift man n take pics, cant wait to see that car in action!
Old 12-09-2006, 07:15 PM
vette-oholic
vette-oholic's Avatar
wow. can i drive her
Old 12-09-2006, 10:55 PM
macsperformance
The car is over 200 miles away now, so I can not help with the pictures. The man that built the kit for the car Walker Morgan has pictures of the build. He will be adding them to his website soon. www.mpfab.com
thank you
Chris Macellaro
Quick Reply: [Z06] 2006 C6 Z06 Twin Turbo with Pictures and Dyno Graphs
