C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Small rocks between rocker panel and quarter panel
Old 01-29-2008, 08:54 PM
Wndotintman
Wndotintman's Avatar
Default Small rocks between rocker panel and quarter panel
I did a search and couldnt find anything. Is there a way to keep rocks and debris getting lodged between the quarter panel and rocker panel. Thanks.
Old 01-29-2008, 09:05 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
It is a very poor design. Take the screws out and get all of the rocks out. Then fill with foam for insulating windows and tighten all the screws. This worked for me.
Old 01-29-2008, 09:12 PM
65vetteC6
65vetteC6's Avatar
http://www.nakidparts.com/id22.html
There are the how to instructions.
Old 01-29-2008, 09:13 PM
Wndotintman
Are you talking about removing the inner fender? Thanks.
Old 01-29-2008, 09:15 PM
Wndotintman
That explains it. Thanks alot!! I appreciate it.
Old 01-29-2008, 11:25 PM
GMuffley
GMuffley's Avatar
Silicon seal in the gap works as well.
Old 01-30-2008, 12:57 AM
kentz06
kentz06's Avatar
Very dark sun glasses also work well...
D
Old 01-30-2008, 08:30 AM
Foosh
Foosh's Avatar
Received 16,668 Likes on 8,311 Posts
For anyone on the fence, the procedure linked above is unbelievably simple and effective. If you can fill your car with gas, you can do this. I did it more than 18 months ago, and still have zero pebbles held hostage.
Old 01-30-2008, 08:47 AM
curvesman
curvesman's Avatar
C2 of the Year Finalist - Unmodified 2020
Old 01-30-2008, 09:36 AM
vetdude
vetdude's Avatar
great tip.
Old 01-30-2008, 10:52 AM
WestxC6Zo6
WestxC6Zo6's Avatar
Thanks...i dropped the bolts loose and a pound of small gravel fell out!
Old 01-30-2008, 11:54 AM
Jman34
Jman34's Avatar
I did this several months ago and it was a very easy and effective solution for sure.
Old 01-30-2008, 01:36 PM
v.vet's Z06
v.vet's Z06's Avatar
Thanks for the tip. 400 miles on my car and I spotted a few of those guys. Off to Ace Saturday!
Old 01-30-2008, 03:23 PM
DSOM Z06
DSOM Z06's Avatar
Do you need to use a lift?
Old 01-30-2008, 03:39 PM
Torched
Torched's Avatar
Thanks for the tip. One of the first thing I do when my 08 Z shows up end of FEB.
Old 01-30-2008, 03:40 PM
rob62
rob62's Avatar
Received 1,733 Likes on 874 Posts
Have acumulated a large collection with a mere 300 miles.Dont recomend trying to remove them without loosening the rocker panel.C5Z have the same problem but you cant see them as much.When I cleaned them out I had a pile 3 inches high on both sides!
Old 02-03-2008, 02:50 PM
DSOM Z06
DSOM Z06's Avatar
what type of weatherstripping is that? I can't make out the second word...Sponge something.
To Small rocks between rocker panel and quarter panel
Old 02-03-2008, 03:25 PM
Torched
Torched's Avatar
It's made by the company ACE. It's closed cell(firm sponge) weatherstrip. I had a real hard time finding this ACE product in the exact dimensions so i finally had to order it from an ACE store. Keep in mind I believe the picture is from the old packaging which made it harder to locate.ACE still makes it in a new package. Good luck.
Old 02-03-2008, 03:46 PM
DSOM Z06
DSOM Z06's Avatar
Think I found it here...
http://www.acehardware.com/product/i...ductId=1287006
Old 02-04-2008, 09:48 PM
Torched
Torched's Avatar
I didn't want to order from the site it says nothing about dimensions. I got 1/2", 1/2" 10ft by ordering in a local store. Takes about a week to get it.
Quick Reply: [Z06] Small rocks between rocker panel and quarter panel
