[Z06] Help me please
Exhaust valve has turn off and contact with the piston and after that the connecting rod has punched the block((((((( and i have big hole in my engine block(((((( I have order block two month ago,through the local tuner, but this tuner have problem with my order, he say GM Performance in USA have not LS7 blocks((((
I have friend in miami,he can buy block and sent to me!
Give me please more shop . . .
I want be ready for next season))))
Excuse for my bad English
Thank you
Thank you
Thank you
Thank you
http://www.jegs.com/i/GM+Performance...65058/10002/-1 (Information on site,ships today) but this is engine with heads and more, i nedd only block with pistons,crank,rod . . .
I needed a block but to avoid delays and uncertainties about supply I eventually bought a complete new crate engine, which was more readily available here in the UK
I think blocks are available if you have good friends!!!
If you want a complete LS7 engine - PM me.
Sounds like you better include forged pistons as well on your rebuild list !
