[Z06] speed bleeders leak!
just installed a full set of brand new speed bleeders, what a waste they are the SB1010S.
all of them are tightened down snug, 4 out of 8 are squirting fluid all over the inside of my wheel, getting those things swapped back to OEM asap! anyone else had this problem?
also after the bleeding job i noticed a click sound coming from the fuse panel underneath the passenger floor mat whenever i press the brake pedal. is this normal?
I bleed and flush the system before and after every track event, so I've been cracking them open and closing them back up numerous times, and I have had absolutely no problems with them. I think they are great for solo bleeding/flushing.
I believe I have the same ones you're using. I can't remember the exact model# I got, but I just looked at their site and see that's what they recommend for Corvettes, and when I got them I ordered what they specified.
Sorry you're having problems, but mine work great!!!
Bob
I had speedbleeders on my c5 for several years with no problems and am getting ready to order four more for the c6 z. I am assuming that the old ones are still good.
Now for what it's worth. the patent for speed bleeders has run out. I would only buy them from the original source speedbleeder.com or call them at 1-888-879-7016. I just spoke with them the other day. The ones they sell are made by them in the good ol' USA exactly like they were making them before the patent ran out, other vendors buy only some from them in order to be able to use the speedbleeder name. the rest of their inventory "may" come from China. The other thing that may make a difference, the ones that I had been using and will re-order are the SB1010s-ss the "ss" is for stainless steel.
good luck
good luck
Former Vendor
I don't see the reasoning behind them. Those of you who are using them to do a one person bleeding, how do you know when you have passed all the air out if you are pumping the pedal and noone is watching the bleed line? Maybe with a pressure bleeder, but with that, you don't need the speed bleeders. I just don't see the point.
Mine are total overkill because I use a Motive Power Bleeder to pressurize the m/c. I don't need the Speed Bleeders at all, but I like them.
Bob
Have been saying the same thing for years on this forum.
Don't screw with what works.
With them, I can bleed the brakes with my 4 yr old watching for, as he says, "no bubbles". He can also pump the pedal, because if he slips up, the valve always closes, keeping the air out.
I have Speed Bleeders too - I've had them in for about 1-1/2 years now.
Bob
Bob
DH
good luck
good luck
DH
a buddy of mine was a local distributor for them here about 2 years ago...when i was gonna order a set from him last year, he told me that he stopped carrying them, as too many people complained that they were leaking...
he carried the originals, not knock-offs too...
turned out the speed bleeders ruined the valve seats inside the calipers, the shape of their tip is slightly different than stock...stock on the left, speedbleeder on the right...
these are the SB1010S that they sent me, ordered online directly from their website. i did not overtighten them as i have used them on other vehicles before and loved them, thats why i got them. after installing them i went to bleed and noted that the ones i was not bleeding were slowly dripping fluid. i gave the leaking ones a smidge more torque and this did not fix the problem. with the weekend over i had run out of time to mess with it and took it over to LG. Anthony informed me that the valve seats were ruined and that even the stock bleeders would not seal.
with a HPDE the next day i was understandibly freaked. Anthony and the LG guys saved the day by tapping out the calipers for Wilwood bleeders. ran the HPDE the next 2 days and everything worked flawlessly, including the brakes. never buying speedbleeders for anything again. waiting on a response from them...
Former Vendor
for future reference for anyone else who strips and wants to fix themselves, autozone sells a bleeder repair kit. You slightly open up the bleed hole with a drill and retap to 1/8" NPT (I think, might be a little off on the size, but thats unimportant), then you install a threaded insert with a smaller bleed screw in it, pretty much just like the wilwoods nzk used.
