[Z06] EnglandGreen Cam Package - everything including the Kitchen Sink!!!!
Supporting Tuner
We have been getting a lot of requests for a complete camshaft package for the C6 & C5 Corvettes.
This is everything needed for a DIY cam swap. So we have put together a package for the DIY members that want to do their own labour.
This package includes everything down to Red Locktite. All you add is your own labour and tools.
Price is $1595 shipped to the lower 48 states.
Always remember, you WILL need a computer tune after a cam swap - so factor in some $$$$ for that item.
Our cam package contains the following parts:
1 x EnglandGreen custom grind cam
1 x GM Front Cover Gasket
1 x GM Front Cover seal
2 x GM Waterpump seals
1 x GM Crank Bolt
1 x GM LS2 Timing Chain
1 x GM Oil pump pickup O-Ring
1 x High volume, high flow oil pump
1 x 160 degree thermostat
16 x Patriot Extreme dual valve springs with titanium retainers
16 x 7.400 inch chromemoly hardened pushrods
1 x 25% underdrive crank pulley
1 x New serpentine belt
1 x tube of Red Locktite
OK. We admit that there actually isn't a kitchen sink included - but everything else is!!!
Lots of vendors sell custom camshafts - so what's so special about the "EnglandGreen Signature Cams"???
These cams will not be your usual grandfather-type baby cams - they are all loud, obstreperous, will shake your Vette and make your neighbours hate you!! With the exception of my Ninja cam™, none of them are for the faint of heart. In all cases, they will need a custom tune and if automatic, you will need a stall converter (exception : Ninja cam™).
They are all designed to be blower and turbo friendly, but will work perfectly in a naturally aspirated application as well. More importantly, we can tune them so that they drive very close to stock!!!
Just a tiny sampling of Corvette Forum members running our cams :
EG@EnglandGreen (me) - 402ci Paxton Novi 2000 supercharger with Insanity cam™ in a 2001 C5 A4
Cajundude@EnglandGreen - 402ci modified STS TT with Whiplash cam™ in a 2002 C5 MN6
UWILLUZ - 2002 C5 Z06 383ci ATI F1R supercharger with Godzilla cam™
UWILLUZ - 2008 C6 Z06 427ci with Insanity cam™
Mondaine - 2002 C5 Z06 Paxton Novi 2000 with Whiplash cam™
Bill Curlee - 2002 C5 Z06 Patriot heads, FAST 90/90 and Whiplash cam™
Carl Spackler - 2000 MN6 Vert P1SC supercharger with Whiplash cam™
Kenny Sibley - 2003 C5 Z06 with mayhem cam™
c6user - 2007 MN6 C6, Trickflow heads and Whiplash cam™
kbobk - 2008 MNZ C6 and Whiplash cam™
NTRBL33 - 2005 MN6 C6 and Whiplash cam™
p_dubya - 2003 C5 Z06 and Whiplash II cam™
jvas - 2000 C5 A4, stall and Whiplash II cam™
99C5-TA - 2008 C6 Z06 with Mayhem II cam™
TXZ0603 - 2003 Z06 with Whiplash II cam™
We have revamped our cam line to reflect the feedback we have received from our many customers. By far, our Whiplash cam™ has been our most popular offering. However, many customers have been asking me for a "stealth" or silent cam as well as a nasty cam that is bigger than our Chaos cam™ but smaller than our Insanity cam™. We also realized that our midrange cams were showing their age and we have now redesigned our midrange cams to reflect what our customers have been asking for.
Originally, we used Comp's excellent XE-R lobes, but after working with Comp for more than 6 months, we have collectively designed a new lobe profile; these are not catalog cams nor are they clones of anyone else's cams.
Here is our new cam lineup :
* EnglandGreen Ninja Cam™ : brand new stealth cam with no chop at idle with an exceptional flat torque curve - wide intake/exhaust spread and LSA in the 118 range. No one will know that your Vette is cammed!
* EnglandGreen Havoc Cam™ : wreak havoc with our new creation cam in the high 220/low 230s duration range
* EnglandGreen Mayhem II Cam™ : formally our Mayhem Cam™, but now completely redesigned - and much larger! Duration is in the low 240s range.
* EnglandGreen Whiplash II Cam™ : Best Seller!! Duration in the mid 240s and extremely aggressive.
* EnglandGreen Chaos II Cam™ : formally our Chaos cam™, but completely redesigned and significantly bigger. Duration is in the low 250s
* EnglandGreen Black Rage Cam™ : Our latest creation. For use only in big cubic inch motors. Duration is in the high 250s/low 260s duration
* EnglandGreen Insanity Cam™ : This cam is for the seriously mentally disturbed among us. Duration is in the low 270s
So give us a call of drop us an email if you want to order this cam package. We also install and tune these packages at our shop in Houston, Texas for just $2995. We accept all major credit cards.
Stephen Rawlins
Phone: 281 464 2800
Email: sales@englandgreen.com
AIM: englandgreeninc
Video of the EnglandGreen Whiplash cam™
Video of the EnglandGreen Whiplash II cam™
EnglandGreen Whiplash II™ cam, Part 1
2003 C5 Z06, Vararam, AR headers, high flow cats, stock Titanium catbacks
EnglandGreen Whiplash II™ cam, Part 2
2001 C5 Coupe, Vararam, LG Streets headers, high flow cats, B&B PRT catbacks
EnglandGreen Insanity™ cam
2008 C6 Z06, Lingenfelter package of Kooks headers and Callaway Honker, B&B Fusion catbacks. Stock heads. Dynoed at 569rwhp
Supporting Tuner
