[Z06] Cross beam adapter for jacking?
Using one of the methods in the FAQ, you purchase 2 cross beam adapters from NorthernTool.com, remove the rails for the front - reattach rubber pads on center piece, modify to fit your jack (i'll be using the Omega 29023) and jack directly on the "preferred jacking points" on the cross beams.
Sounds great...one minor problem. NorthernTool.com doesn't sell the cross beam adapters anymore.
This is the only thing I can find similar to the NorthernTool one...
http://www.dsuban.com/3167-Cross-Beam-Adapter-p871.html
Anyone know if this will work? Any other cross beam adapters?
You can make one out of wood for much less.
you seem to have your mind made up on these so why even ask. a cut piece of wood for under $10 will do the same job. but if you want these things then just get them. i thought i saw a post where you have to modify one anyway cause the reach on them is too far.
yes because cutting a 2x6 to length is extremely difficult.
Like this right?
I used a wooden brace with a similar design on my C5. I know it works.
For $50 more
I have an extra $50 to spend.
Go here
http://www.cvfsupply.com/shop_tools/...ross_beam.html
Cross Beam Floor Jack Adapter - 2 ton.
Cross beam floor jack adapter is designed for floor jack use only.
Adustable from 27" to 34" wide.
Adjustable pads on each end allow for even and balanced lifting. Each end has approx. 3" of adjustment capability.
Ideal for 4 wheel drive, or front wheel drive vehicles.
Mounts to most common floor jacks.
2 ton capacity.
Shipping weight - 31 lbs.
Availability: Usually ships the next business day
MS021 $49.95
Hope this helps.
James West
Omaha, NE.
2 ton capacity.
MS021 $49.95
Hope this helps.
James West
Omaha, NE.
