C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Where is Chassis Lubrication spot?
Old 04-21-2009, 03:43 AM
jm4471
jm4471's Avatar
Default Where is Chassis Lubrication spot?
I have 07 Z06 and I can't find any Chassis Lubrication spot. I think I need to lube every oil change right???
And where the heck is the REAR TOE-LINK OUTER ENDS???
Old 04-21-2009, 04:31 AM
mousecatcher
mousecatcher's Avatar
i think there is only 1 spot -- rear toe link. it should be blindingly obvious.
Old 04-21-2009, 07:10 AM
GOLD72
GOLD72's Avatar
Received 1,106 Likes on 718 Posts
From underneath the car, it is easily spotted by looking at the inside lower rear quadrant of each rear wheel for the grease zerk fitting. Also true of the Z51 & 07 and later F55 optioned vettes.
Old 04-21-2009, 08:49 AM
DSteck
DSteck's Avatar
Anybody got the procedure for doing this?
Old 04-21-2009, 11:31 AM
GrillnZ
GrillnZ's Avatar
For operating a grease gun?
Old 04-21-2009, 11:46 AM
06-Z0SICK
06-Z0SICK's Avatar
put the end of the gun on the grease fitting and squeeze away!
Old 04-21-2009, 12:07 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Here ya'go!!!
http://www.nakidparts.com/id47.html
Bob
Old 04-21-2009, 12:46 PM
DSteck
DSteck's Avatar
I don't do suspension stuff... I do motor/tuning stuff.
Old 04-21-2009, 12:51 PM
WFO
WFO's Avatar
Thanks fo the Thread. and website for Nakidparts grease info.
Although the instructions are for Z51! equipped cars.
Why doesn't this address Z06's?
Old 04-21-2009, 12:55 PM
GOLD72
GOLD72's Avatar
I don't know but the same procedures should apply to the Z06 and F55 suspension cars as well.
Old 04-21-2009, 01:02 PM
GOLD72
GOLD72's Avatar
I would be careful about that. For a street car, 2 or 3 pumps should be enough. The problem is that the inside disc surface is very close to the grease boot. You can insert too much and have grease squeezing out onto the braking surface of the disc from the rubber boot. Not good. Plus it might not squeeze out until you drive it some. Not good either. When front steering/suspensions used to have grease zerks, excess grease leaking out a day later was common. I have "greased a few front ends" in my time.
Old 04-21-2009, 11:40 PM
kuyarog
kuyarog's Avatar
Here they are on an '08Z.
Roger
Old 04-22-2009, 12:08 AM
jerseydrew
jerseydrew's Avatar
how often should this be done? (manual is in the car)
Old 04-22-2009, 07:02 AM
GOLD72
GOLD72's Avatar
For a DD street car, I do it every 7500 mile oil change. I would only give it 2 or 3 pumps at most per fitting.
Old 04-22-2009, 10:33 AM
teds427
teds427's Avatar
While your under the rear of the car check the sway bar mounting bolts, mine were backed out on both sides.
Ted
Old 04-22-2009, 10:40 AM
Larry T
Larry T's Avatar
...make sure that after you lube the zerks that you wipe down the fittings and joints with a shop rag...
Old 04-22-2009, 11:20 AM
urslooow
urslooow's Avatar
thanks for the tips
Old 04-22-2009, 05:35 PM
jm4471
jm4471's Avatar
thanks
To Where is Chassis Lubrication spot?
Quick Reply: [Z06] Where is Chassis Lubrication spot?
