[Z06] let's here it, who has blown up their stock Ls7's
#41
#42
I understand, and thanks for the explanation.
Hypothetically speaking, were you to own such a car as the Z06, and have it's engine fail, would you be inclined to state that the car was modified, if that were the case, knowing that hypothetically, the warranty for a new engine might be denied as a result of said statement?
Also, hypothetically, which types of pictures, and specifically what pictures, or other evidence would one hypothetically want to gather in support of their case, and to protect themselves, were such a mishap to occur?
What would one need a picture of in order to protect themselves in such a matter?
Thank you.
Again, all of this is completely hypothetical.
Thank you.
#43
Hypothetically, if I were to buy a Z06, it would probably be because, in my opinion, it requires no performance mods in the drivetrain. That coupled with the fact that I would not want to be left with the $13,000 bill for a new engine + additional parts + labor if said car were to have it's engine disassemble itself at a high rate of speed and velocity due to a defect in the design or manufacturing of said vehicle. So, hypothetically, I would not be inclined to modify the drive train of such a car. Especially with it's history of catastrophic engine failures. Furthermore, I would then not need to lie or fail to disclose any modifications of said vehicle simply because it would be true.
So the lesson to be learned here, is that all of this is hypothetical.
So far, I'm not seeing that many repoorts of stock engines, with stock tunes, failing in these real cars.
We know about the batch of bad rockers which found their way into a few of the '07 models.
I have heard of very few stock '06, '08s, or '09s failing.
Hypothetically, if you were to buy a Z06, what year would it be?
#44
#45
Well so far it looks like about 5 or 6 engine failures. 2 or 3 of which are track only cars.
This of course doesn't count the ones that people saw in service bays elsewhere. But those are just hearsay.
#46
Got it.
#47
I snapped my #1 exhaust valve & then it drop! Motor gone. At the time, I had 17xxx miles. Mostly track miles & driven at 7k rpm all the time. It had CAI, headers, cam & tune mod work on motor. It is an '06 C6Z. Never bother taking it to the dealer. On my 2nd motor now with about 4k miles on the new motor & 2 track days. Slowed down a bit on track days cuz of $$$$. Don't have $$ for tires. But she's all paid for & I plan on keeping her!
#49
A guy here in town lost his bone stock 08Z last fall (oil starvation). I lost My 08Z earlier this month. I broke the #5 piston and cracked the sleeve. My mods were heads, milled .020 and mild cam/tune. An instructor at he last HPDE I attended is on his 3rd motor, all bone stock.
#50
How is the resleeve going?
Also, what tires were these cars on if you know?
#51
#53
Location: Bend, Oregon Black / Ebony 2LZ 2006 Z06 C6Z06 owner since 2/7/2006
Not many engines can take that kind of abuse for 17K miles. There are other unmodded C6Zs that also have 10-20K track miles and have not suffered engine failures.
I suspect our cars are typically driven harder more often than some of the more expensive European cars. That is what most likely accounts for the possibility of higher rate of failures.
My '06Z is bone stock and not one issue.
Tom
NavyAirTraffic (09-24-2023)
#54
From what I am seeing this is a very fragile engine indeed. There are many N/A engines out there from other manufacturers that take much more abuse and last much longer and aren't even exotic.
I am very concern. For a $13000 engine it should be way more solid than that.
#55
#56
Some examples of 500-600 hp NA engines that are more reliable with equal abuse please.
#57
Mercedes AMG put their N/A 6.2 +5xx motor in just about every freaking car they produce
Aston Martin's +500 N/A motor is good too.
Ferrari is self-explanatory.
Lamborghini self-explanatory.
Audi has a model or two IIRC.
Etc.
But your question is off topic from the thread.
PLEASE STAY ON TOPIC
#59
This wouldn't be the argument I would use were I attempting to defend the reliability of the LS7.
Etc.
Etc.
Oh. Stay on topic.
#60
And . . . You're right! ONLY Ferrari and ZO6 owners go to the track (sarcasm intended )
Back on topic
