C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Two Problems
Old May 10, 2009 | 07:08 AM
Cor Dame's Avatar
Cor Dame
Default Goodbye
Goodbye
Old May 10, 2009 | 08:56 AM
Undy's Avatar
Undy
What year and model?? The fuel gauge issue was peculiar to the C5s.. This will help give us a point of reference.
Dave
Old May 10, 2009 | 09:02 AM
Flareside's Avatar
Flareside
Originally Posted by Cor Dame
Hello guy`s i hope you can help me out because the dealer is not lognger a dealer and the import company "Kroymans" is not longer exsisting anymore.
Corvette owners like me are on there own now and warrenty is a big problem now here in The Netherlands.
Problem one is that i can not get my car in reverse.
I have tried every thing like engine off or on etc but it won`t go in reverse.
I have a MGW shifter but i have never had this problem with this shifter in the past.
I don`t want to blame the shifter because it is a fine peace of craftmanship.
Enybody else had this problem?
Problem two is dat a get the message "service fuel system"and that my fuel gage is standing on zero all the time.
This proble, occured when i was cumming back from skieing in france.
I was lucky that it occurd 10 miles before a gas station becaus the gauge was standing on half full en sundenly it was on zero.
When i was filling up the tank was almost completely empty.
Could this be a sensor in the fuel system or is the gage defect and how can i check this?
thanks in advance and grtz from the Netherlands,
Hans
The car has an electronic solenoid on the transmission that blocks reverse if the car is moving at more than a few mph. You probably have a problem with that system.
Old May 10, 2009 | 09:06 AM
Undy's Avatar
Undy
Hans,
I'd go through the motions and readjust the stops etc on the MGW shifter. If you still have the old shifter I'd probably reinstall it to see if the OEM one corrects the problem. Also, check you clutch master cylinder for fuild level and color of fluid (should be light amber).
Get a hand scanner, a "CAN enabled" model is needed. Pull the codes and get back with us. This all is if you've no dealer at all to go to.
Dave
Old May 10, 2009 | 09:36 AM
atomicfusion's Avatar
atomicfusion
Hans
I had the reverse issue when my clutch was going out... if you push REAL HARD it should go in, but I had the same issue and a new clutch solved the problem. You may also just try changing your clutch fluid.
As for the fuel system issue, that is something that will require a mechanic. There is probalby a problem with the pickup and the tanks will need to be dropped to get to it.
Old May 11, 2009 | 12:21 AM
ZL-1's Avatar
ZL-1
Reverse: Check the underhood fuseblock and see if #13 fuse is blown. This controls the reverse blockout solenoid.
Fuel gauge: It's possible that you got a tankful of gas that was high in sulfur or some other contaminant. This can foul the fuel sensor cards. If the ECM sees erratic fuel readings it sends the gauge to "E". Here in the US a can of Techron fuel system cleaner will sometimes correct the problem. Don't know if that or a similar product is available in Europe.
Old May 11, 2009 | 06:05 PM
WFO's Avatar
WFO
Hans..If all else fails check with your local Corvette Club out there (if you have one)? They should know of a good reputable performance Tuner that works wonders on LS motors.
Old May 14, 2009 | 03:24 PM
DSteck's Avatar
DSteck
Will the shifter go far enough over for the reverse gate, but just not go in? Or, will the shifter not go past the 5/6 gate? If you can get to the reverse gate, and the car is totally stationary, then with the engine running... SLOWLY let off the clutch and try to push into reverse. If it starts to grind or anything, push the clutch back in and give up. If it goes in, push the clutch back down, and then try to let up on it and move.
Old May 14, 2009 | 03:44 PM
JiminVirginia's Avatar
JiminVirginia
Running your gas tank down to virtually empty can damage the sending unit. The remedy is to replace the entire fuel pump, as I understand it.
But it's worth trying an additive and maybe, as someone on the Forum once advocated, disconnecting the battery.
Let us know how it plays out, and good luck.
Old May 15, 2009 | 10:55 AM
Curz's Avatar
Curz
sorry to hear that
I had the same issue with fuel - I had to get the sensor in the tank replaced
Old May 15, 2009 | 11:20 AM
Daytona-flyer's Avatar
Daytona-flyer
The fuel gauge is a known issue. I had to get the computer reset and the dealer gave me a bottle of GM fuel system cleaner. He said it is caused by the high sulphur content in the gasoline.
Old May 15, 2009 | 11:40 AM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
Put the car in gear and see if you can move the shifter left to right with some moderate force. If you can, the shifter linkage is slipping on the shift rod. Remove the shifter and thighten the bolts that connect the shifter to the shift rod.
Old May 15, 2009 | 01:18 PM
Lawdogg's Avatar
Lawdogg
Let us know!
Old May 15, 2009 | 03:49 PM
z0sicks07's Avatar
z0sicks07
if it feels like it doesnt let you go all the way right to go into reverse position that is the reverse lock out and it is going to be a solenoid issue
Old May 15, 2009 | 09:37 PM
McMung's Avatar
McMung
If you do pull off the console and check the shifter linkage clamp bolt & shifter box mounting bolts, make sure the gear lever (MGW) is vertical when the gearbox is in neutral. If it is not you can clamp the shifter linkage down misaligned such that the MGW running into it's own stops (inherent to the pivot mechanism in the MGW) before getting "far enough to the right" to engage the reverse gate.
That would be the only mechanical problem I can think of, everyone else is right when they talk about the reverse lockout sol. being a potential electrical problem. Definitely you need to get a scan tool that supports CAN (look for those that specifically support "GMLAN" and "GM Class 2") and get any diag codes with it we can look up their definition and show you corrective action.
Hey look on the bright side, now that you have no warranty you can go nuts with modifications!
Old May 16, 2009 | 01:43 PM
McMung's Avatar
McMung
I have checked the shifter and any bolt that i could find but everything is ok.
It must be the solenoid on the gearbox then.
The problem now is that the dealer couldn`t make contact with the computer of the car.
8 month`s ago they placed a new engine, could it be possible that they damaged a cable or so?
Two weeks later a hydraulic valve lifter broke.
I have changed a lot of things on the car but i will do nothing on the engine because it is not bullit proof.
A company here in holland that does make a lot of race engines showed me the weekspots of the engine.
The valve lifters i have now are from caddilac because the can handle better high rpms.
I also have a other dry sump,oil cooler and oil pump and in the oil tank is an other reservoir placed.
So no modifications on the engine for me.....
Grtz,Hans
You're using caddy lifters, you did just modify the engine...
Re: those lifters, the aftermarket is apparently much better quality: http://forums.corvetteforum.com/nort...v-lifters.html
To Two Problems
