C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] DIC Code retrieval?
Old May 16, 2009 | 12:29 PM
FastestBusaAround's Avatar
FastestBusaAround
Default DIC Code retrieval?
Is it possible to retrieve the DIC codes off a C6Z, or do I need a reader/scanner? From the searches I've done, it seems there's no way to get them without using a reader...I've get a CEL and want to know what the code is...
Old May 16, 2009 | 12:40 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
No one has described a method of retrieving DTCs from a C6 without a tuning software or a code reader.
Old May 16, 2009 | 12:42 PM
FastestBusaAround
Well, I guess that answers that then...thanks!
Old May 18, 2009 | 06:19 AM
sbadd99's Avatar
sbadd99
must be do able
Old May 18, 2009 | 08:31 AM
jvp's Avatar
jvp
"Ask Tadge" Producer
Originally Posted by sbadd99
must be do able
It isn't. They removed that feature from all C6s. You need a CAN-enabled code reader to read the PCM codes, and a Tech-2 (or something similar) to read the rest of them.
jas
Old May 18, 2009 | 04:47 PM
PCBeachDP's Avatar
PCBeachDP
Default OnStar
You can call OnStar and they will run a diagnostic and tell you what the error is. They will even schedule an appointment with a dealer if you need it.
PCBeachDP
Old May 18, 2009 | 06:13 PM
Bill Dearborn's Avatar
Bill Dearborn
PCBeachDP
Sometimes they will give you the code but a lot of times they will not answer your question if you ask what the code is. Been there done that.
Bill
To DIC Code retrieval?
