C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Clutch
Old 06-04-2009, 11:27 PM
jmattes
jmattes's Avatar
Default Clutch
What is the sighns of the clutch going bad? I have 2006 z06, and sometimes it hard to put it in reverse.
Old 06-05-2009, 12:03 AM
NandoZ06
NandoZ06's Avatar
Mine did that once at the dragstrip.,but its still good under normal drivin conditions.
Old 06-05-2009, 12:08 AM
Omega Man
Omega Man's Avatar
Location: I speak the truth. Harsh but accurate. The Woodlands Texas
St. Jude Donor '09-'10
You need to read the Sticky by Ranger on clutch maintenance. might help answer some of your questions.
http://forums.corvetteforum.com/c6-z...-and-cure.html
Old 06-05-2009, 12:14 AM
QTR-Z06
QTR-Z06's Avatar
hmmmm .. well .. if you down shift and press hard and felt that there is a high rev with your foot off the clutch .. that means they're way beyond bad ... lol .. other than that i guess your fine .. it will loosen up eventually
To Clutch
Quick Reply: [Z06] Clutch
