C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] DIY - LPE High Capacity Oil Tank Installation
Old 06-22-2009, 07:34 PM
Dreamin
Dreamin's Avatar
Default DIY - LPE High Capacity Oil Tank Installation
This is a fairly easy, do-it-yourself project... it'll take ~3 hours working slowly with two people. The second person is only required to help guide the tank in/out of the fender. It's possible to do with one person, but will take longer.
Thank you to members 2002rich and Moss for their help
The reason I installed the LPE tank is HERE. The tank fits like a glove! Workmanship is first class.
Pics below are from a 2007 Z06.
*** Standard disclaimers apply. I assume no responsibility for any damage. Please be careful - the consequences of a mistake or improper install could be disastrous ***
Tools
* 7mm to 16mm sockets
* Suitable wrenches / extensions
* Optional: 'grabber tool' and blue tape
* 12 quarts of oil
Oil Tank Removal Steps
Step 1) Raise Car; Remove front passenger-side wheel; Drain oil
Step 2) Remove fender liner
Remove four bolts from bottom of liner
Remove two plastic push-pins from side of liner
Liner is attached to the fender with metal push-clips. Start at lower portion of liner and working upward, carefully pull liner off fender.
Remove one bolt holding fender... this is needed to push the fender out of the way a little for tank removal / installation.
Step 3) Unbolt top of oil tank
Mark one of the oil vapor lines so they don't get swapped when reinstalling (I used yellow tape).
Remove vapor lines by twisting locking tab clockwise and pulling the lines off
Remove two bolts from middle bracket
Use 'grabber tool' to prevent dropping the bolts
Remove one bolt from top
Step 4) Unbolt bottom of tank
Remove oil temp sensor wiring harness
Remove oil lines from bottom of tank
Remove two bottom bracket mounting bolts
With one person holding the top of tank as needed, move bottom of tank to the side and disconnect oil lines; Let oil drain out of lines.
Step 5) Remove tank from car
With one person working at the top and one at the bottom, slide tank down to remove. Carefully move wiring harnesses out of the way.
Step 6) Separate top and bottom of tank
Mark the position of the tanks so the new tank can be installed with the correct orientation
Separate the tanks
Bottom tank
Top tank
If you're shipping the tank to LPE, you MUST:
* Ship only the bottom half of the oil tank
* Remove the brackets bolted to the bottom of the tank
* Remove the oil temperature sensor
* Remove the silver oil tube (if lifts straight up)
* Remove the black plastic oil screen (It uses locking tabs. Remove by wiggling/pushing the screen toward the 'outside' of the tank)
* Wipe the tank clean of any oil
From their website: If you do not remove these items you will be charged an additional labor and handling charge.
Dreamin
Dreamin's Avatar
Oil Tank Installation Steps
Step 1) On new tank: install bottom brackets, oil temp sensor, and oil line screen
(Push screen into bore from outside the tank until the locking tabs locate in the groove)
Yes, It really holds 3 more quarts
Step 2) Reassemble top and bottom of tank.
Tighten bolts/studs to 18 lb-ft
Step 3) Replace two oil seals on bottom oil tank lines
Oil Seals are supplied by LPE
Step 4) Reinstall new tank
With one person working at the top and one at the bottom, slide tank up into place. Take care not to pinch any of the wiring harnesses in the way.
Install oil lines. Tighten two bolts to 16 lb-ft
Install two bottom backet bolts. Tighten to 27 lb-ft
Install three top bolts. Tighten to 89 lb-in
Installed tank...plenty of clearance once it's in place!
Step 5) Refill tank with oil
Mine took almost 12 quarts... but i believe an oil change will take 11 quarts +/- as you won't drain all the residual oil in the tank and oil lines.
That's it... go out and enjoy your new LPE Oil Tank.
KaiserM715 (02-07-2019)
Old 06-22-2009, 07:45 PM
dvandentop
dvandentop's Avatar
very awesome post as usual, thanks for the tips, now when are you going to be doing the testing??
Old 06-22-2009, 07:50 PM
patch68
patch68's Avatar
Great post ! Thanks
Old 06-22-2009, 07:55 PM
shifter77
shifter77's Avatar
GREAT investment. Total cost after tank exchange?
Old 06-22-2009, 08:02 PM
DaOtherOne
DaOtherOne's Avatar
Excellent post.
Thank you
Old 06-22-2009, 08:18 PM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
Great job. Do you have any concerns using the stock pan?
Old 06-22-2009, 08:43 PM
burtonbl103
burtonbl103's Avatar
St. Jude Donor '06-'07-'08 & '12-'13
Old 06-22-2009, 08:53 PM
Dicecal
Dicecal's Avatar
Nice, now awaiting your test results with the LPE tank!
Old 06-22-2009, 10:27 PM
Moss
Moss's Avatar
Nice Write up as usual.
Old 06-22-2009, 10:35 PM
CudjoeScott
CudjoeScott's Avatar
St. Jude Donor '09-'10-'11-'12
Excellent Eagerly awaiting your results.
Old 06-22-2009, 10:46 PM
2002rich
2002rich's Avatar
Great write up
I'm glad you replaced the stock tank with the LPE. Hopefully your engine will be happy you did too Will shall soon see
Old 06-22-2009, 11:26 PM
66L72
66L72's Avatar
Excellent write up Dreamin.
Thanks for helping us out on this project.
I see you did not install the Aviaid baffle. Is that step 2 after doing some testing just with the LPE tank?
thanks again
Old 06-22-2009, 11:30 PM
linutux
linutux's Avatar
Fantastic write-up!!!!
I never would have thought of doing this myself without this info; now, I may give it a shot.
LPE should give you a solid discount for priming the pump... so to speak.
Old 06-22-2009, 11:56 PM
jlvink66
jlvink66's Avatar
Thanks for the detailed "how to" post! I'll be doing my LPE tank install in the next two weeks. This will help me immensely. I am also installing the Aviaid tank baffle so I will add the unique info on the installation of that component to this thread.
This is just one of the mods that I have to finish before our event at Laguna Seca so I hope I get it all done in time.
John
Old 06-23-2009, 12:00 AM
Dreamin
Dreamin's Avatar
June 27/28 - Willow Springs (no starvation previously)
July 20 - Laguna Seca (starvation with stock tank)
Aug ? - ThunderHill (starvation with stock tank)
Aug 15 - Calif Speedway (Banked oval )
Old 06-23-2009, 12:02 AM
Dreamin
Dreamin's Avatar
See HERE
To DIY - LPE High Capacity Oil Tank Installation
Old 06-23-2009, 12:04 AM
Dreamin
Dreamin's Avatar
My oil starvation is very reproducible... i'll retest on those tracks over the next weeks and see how well just the LPE tank works
Old 06-23-2009, 12:05 AM
Dreamin
Dreamin's Avatar
thanks again
I'm still committed to only change ONE thing and then retest
Old 06-23-2009, 12:06 AM
Dreamin
Dreamin's Avatar
It's really very straight-forward
Quick Reply: [Z06] DIY - LPE High Capacity Oil Tank Installation
