[Z06] The best place to find switch 12V
I am trying to find switch 12V in the engine compartment to run my wideband. Where is the best place to find this without having to cut or splice?
I think I figured it out. The fuse box in the engine compartment has both switch and non switch 12v. The only problem is unlike other manufactures there is no grove or slot so you can run wiring into this box. Since you can't buy a new cover without buying the whole fuse box cutting a grove in the cover is not easy decision.
1 Post
SR
