[Z06] DIC Options Screen
1st Gear
DIC Options Screen
After a battery disconnect/reconnect in my 2009 Z06, I noticed that the Options button for the DIC was dead. All other buttons (gauges, trip meter, etc.) worked fine. When you pressed it, nothing would appear in the DIC display. The fuse was fine. Then, a day later and after about 3 or 4 engine starts, it suddenly began working. Is this normal? Do you have to do anything special after a reconnect (such as initializing the windows) for the options to work?
Did you have the engine running in all cases? I think "Options" can only be used with the engine running.
