C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 1-4 Skip Shift Eliminator Question
Old 11-25-2009, 05:59 AM
anthony605
anthony605's Avatar
Thanks! I will give them a try first...
Old 11-25-2009, 12:51 PM
Vito.A
Vito.A's Avatar
Autozone definitely carries them.
You must first blow the fuse.
You can use an older battery charger, or just a jumper wire on your car battery from + to - with the fuse in series to blow it.
Then just remove your old fuse and install the new one. Be careful with the diagram as it can appear backwards and many folks change the wrong fuse.
Old 11-25-2009, 04:05 PM
dmuellenberg
dmuellenberg's Avatar
Originally Posted by GIO-305
Thanks.
I seen that my dash some times light up a 1-4 light when I take to long to shift from 1st to 2nd but I still can shift to 2nd & 3rd with no lock out. I have a 2009.
Unless you have a CAGS eliminator, when the 1-4 light comes on then you can not shift into 2nd or 3rd at that time. However, if you are very slow shifting from 1st to 2nd, the rpms will drop far enough and the lock-out will no longer be active.
Old 11-25-2009, 05:05 PM
xcutter
CF Senior Member
Support Corvetteforum!
xcutter's Avatar
Originally Posted by anthony605
Thanks!! I like the glow fuse trick. Has anyone used it with no problems?
One and a half years with the fuse for $2.00 and it works like a charm.
Old 11-25-2009, 06:29 PM
HamsHall
HamsHall's Avatar
go into 2ND gear @ 19 miles per hour sell your car, your an ***
Old 03-09-2010, 01:30 PM
EdsC6Z06
EdsC6Z06's Avatar
St. Jude Donor '05-'06-'08-'10
Will a C5 cags eliminator plug work on a C6Z? It's the plug on the trans.
Old 03-09-2010, 04:41 PM
VetteVinnie
VetteVinnie's Avatar
Received 1,755 Likes on 1,116 Posts
You know, in over a year and 8000 miles so far driving my Z, I have never once seen the CAGS come on. Fuse box was clean except for the M2W receiver. I wonder if the previous owner did the CAGS eliminator along with the M2W.
Old 03-10-2010, 12:48 AM
Shark Racer
Shark Racer's Avatar
With either eliminator option, you'll see the light come on.
The only way to disable it is via tune, which is what the previous owner most likely did.
I went down the smartglow route myself with this car, and the fuse degraded. I had to remove it due to CEL.
I like the transmission kit the best.
Old 03-10-2010, 06:03 AM
EdsC6Z06
EdsC6Z06's Avatar
Cmon....I know someone knows this. I took my gags plug off my C5 when I sold it and would love to keep it in use.
Old 03-10-2010, 08:27 AM
MachAll 2005
MachAll 2005's Avatar
Default Home-Made
I made my own 5 years ago (before anyone else thought of an alternative to the wiring harness trick) which has worked fine. I have also made several for friends who have had good luck.
Old 03-10-2010, 09:35 AM
bass mechanic
bass mechanic's Avatar
i just blew the fuse and soldered a 10 k ohm resistor across the top of the dead fuse and reinstalled, no problems since. already had an assortment of resistors laying around so my mod was FREE!
Old 03-10-2010, 10:59 AM
ggins
ggins's Avatar
Thanks.
I have 09 too and I usually shift to 2nd after light goes out so I very seldom go from 1st to 4th
Old 03-10-2010, 01:40 PM
  #33
clogan
clogan's Avatar
My CAGS never interferes with my driving. that's 'cause I wind out 1st gear before changing gears. If you are daring enough to wind out 1st gear to at least 20mph (and man, that's slow!!), your CAGS will never show itself.
I just can't see why this is ever an issue for anyone.
To each his own, I guess. No worries here.
CW
Old 03-11-2010, 03:12 AM
  #34
Bud Meyer
Bud Meyer's Avatar
Default Skip Shift
Originally Posted by snide
I eliminate the skip shift with my right foot.
I agree...when I see the skip shift light...my black mamba is asking for more fuel...so I give him what he likes. Problem resolved.
Old 03-11-2010, 03:25 AM
  #35
DJackman
DJackman's Avatar
I got mine 5 years ago from West Coast Corvette for 20 bucks and no problem to this day.
Old 03-11-2010, 04:50 AM
  #36
Shark Racer
Go for it. It works.
Old 03-15-2010, 08:16 AM
  #37
blairR
blairR's Avatar
Originally Posted by RJ60
I used the Smart Glow fuse. Just blow it with a battery charger and install. About $1.80 for the fuse. Cheap and easy. Replace fuse #10.
6 months without any issues. 1-4 light still comes on but the lockout soleniod does not prevent you from shifting to any gear.
I have a 2010 GS which does not seem to respond to the fuse method. I blew the led smart fuse and replaced the #10 fuse with it as instructed, but the skip shift solenoid still seems to engage? Is the CAGS fuse location the same on the 2010? Has anyone else tried this method of disabling CAGS on the 2010?
To 1-4 Skip Shift Eliminator Question
Old 03-15-2010, 08:57 AM
  #38
DSteck
DSteck's Avatar
Pay the money to have it tuned out. I couldn't stand the stupid light. It takes 30 seconds with HP Tuners or EFI Live.
Old 03-15-2010, 01:21 PM
  #39
leres
leres's Avatar
Make sure you have the fuse in the right position:
http://www.xse.com/leres/z06/cags.html
Important: The underhood fuse box is labeled with numbers and letters to identify connector positions. Fuse #10 uses pins D12 and E12. The 10 A fuse next to the "10" (pins A10 and B10) is actually #8 and if you install your CAGS fuse there, you'll disable your parking lights! This is the mistake most people who have trouble make.
Old 03-15-2010, 06:18 PM
  #40
skipdale
skipdale's Avatar
Default Cags
I've had a Z with and without CAGS. I averaged ~3mpg less with. If you can do 60 mph in first, why do you need it? My 2008 shifts easily from 1st to 3rd without CAGS, which may be a factor in my viewpoint.
Quick Reply: [Z06] 1-4 Skip Shift Eliminator Question
