[Z06] exhaust valve ????
exhaust valve ????
what is meant by 2 piece exhaust valve that has been breaking in other threads. explain 2-piece to me please as I must be a dummie as I have never seen or heard of this .... thanks.
They are two pieces. A hollow stem welded to the valve. The stem has sodium in it which improves heat transfer out of the valve. Exhaust valves run at a very high temp as they only see the exhaust gas, not the nice cool intake charge into the combustion chamber. I believe that two piece hollow stem sodium valves were originally designed for aircraft engines, rolls royce comes to mind, but it might have been somebody else.
That is the 64k$ question right there. My guess (and it IS no more than a guess) is that more than the valve head parting from the stem causing the failure, I think the valve GUIDE galls (either through high heat, lack of lube, or both), seizes the valve stem holding it partially open and the piston closes the valve in a bad way. I'd like to read a study of this scenario with heat paths (the cooling passages in the heads)along with oiling capabilities, especially around #7. I believe heat is the root here. (But again, it's just a theory).
Read my report here, http://forums.corvetteforum.com/c6-z...arranty-9.html Actually, I believe the guide gets looser and looser and eventually lead to valve head breaking off. I believe heat is a major factor but might not be the ONLY factor. In my case, the other six cylinders are OK.
