[Z06] Speedometer errors??
Has anyone encountered this?
The logger is a "racelogic" "performance box". The 'g' outputs from the logger agree with the 'g' outputs in the car.
John
Mine was about 8% optimistic.
I recalibrated mine using HP tuners.
The US home market cars - mph speedo - are usually spot on.
John
Why do you always have all the answers?
Mine is Euro spec of course
How did you reprogram it? We tried on the C5 by inputting false tire sizes but that didnt work. I assume there is another way
John
In truth, I have far more questions than I have answers
I noticed on one of the mile runs that I was showing an indicated terminal speed of 187 mph which was rubbish, as the car was standard.
The accurate speed was 173 mph on the day.
The Z06 is plenty fast enough as it is, without the need to exaggerate its speed, and I found the inaccuracy very irritating
I complained about it to GM, and the response I got was that the calibration was optimistic because of the need to comply with EEC regs.
These regs require that a car's speedo must never under indicate it's true speed.
I reprogrammed the speedo with HP tuners - just by trial and error - entering slightly different tyre heights, and checking the speedo readout against my Performance box - till I got it accurate to +1mph
Perhaps before with the C5 you were altering the wrong parameters - perhaps not saving them?
You don't need HP tuners to recalibrate the speedo - some hardware programmes will also allow you to do this.
I have a Hypertech which has this function built in, and I'm sure there will be others too.
Where do you need 1-2 MPH accuracy?
There are 2 straights, one which might be flat in 4th and one which might be flat in 3rd
Currently I shift in both when the big green arrow appears in the HUD. So when i download my data i see that I have not maxed in that gear according to a calculation based on tire diameter and 7,100rpm
That means lost time, a wasted up shift and worse still, a wasted down shift
Watching the rpm on the HUD is a waste of time
I have never heard the rev limiter come on, hence the suspicion that it was the car speedo and not the data logger
Seems I am correct
So all i have to do is recalculate the max speeds per gear by multiplying by 1.06
John
Josh
You will need to read your file first, and access the 'Speedometer' section.
You just enter the new tyre height and click 'commit'.
The module does the other calculations for you.
You then save the new settings to the ECU
Standard set is-
Modified set is-
