C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] GM document for normal oil consumption ridiculous
Old 03-30-2010, 11:51 AM
  #41
why1504
Support Corvetteforum!
why1504's Avatar
St. Jude Donor '17
Originally Posted by Chevy Cust Svc
Hello,
I do apologize for your experience. I am going to send you a private message for more information.
Geoff Allen
Chevrolet Customer Assistance
I am a new Corvette owner. Although I have owned several GMC Yukon's and trucks this is my first Chevy after driving for 35 years. After reading the posts on the engine with that died on the track and this thread on the oil usage I was beginning to wonder if I had made a terrible mistake. I love my Z06 and seeing intervention by Chevy Customer Service quells some of my discomfort. Now, make it right.
Old 03-30-2010, 03:25 PM
  #42
PaintballaXX
PaintballaXX's Avatar
For those asking,
http://www.autoblog.com/2010/03/26/r...s-and-respond/
He may have something to do with that.
Old 03-30-2010, 06:50 PM
  #43
Dirty Howie
Dirty Howie's Avatar
Originally Posted by PaintballaXX
For those asking,
I'm sure you are right. GM cannot afford to lose its customer base. People tend to be repeat buyers if they are happy, not pissed.
I know most guys here have owned more than one Vette and I'm sure the ones on their first one will get another down the road .... if they are treated right.
This is my 6th Vette
DH
Old 03-31-2010, 11:03 AM
  #44
MChicado
MChicado's Avatar
Originally Posted by ttgangsta
I have 24k on mine and it's daily driver, FWIW I drive pretty aggressively and have NEVER noticed a significant change in oil level between oil changes. I put new oil in when the oil meter is at about 5% so ~5000 miles with negligible change in oil level.
Same experience here--even with a few track days on each oil change.
MC
Old 04-01-2010, 02:56 PM
  #45
drbenne
drbenne's Avatar
Update
I was contacted by GM customer service today and informed that my 1 quart per 1000 miles is considered normal consumption on my C6Z06.
So there you have it. I told them that the bulletin number 01-06-01-011E that was sent to me by a forum member states that normal is 1 quart per 2000 miles but no solutions or options were offered.
I appreciate the GM customer service contacting me but I expected some resolution. Difficult to make sense of spending $70K for a vehicle that may burn oil like mine and for which you will have no backing from the manufacturer for a remedy to the problem.
Oh well
Old 04-01-2010, 04:23 PM
  #46
Chalky
Chalky's Avatar
St. Jude Donor '08-'09-'10
Originally Posted by drbenne
Update
Oh well
Sorry to hear. Sounds like the same play, different cast of characters at GM.
Old 04-01-2010, 05:36 PM
  #47
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
Update
Oh well
Do NOT accept this...
My Mercury Grand Marquis, with 200K miles consumes 1qt/2000 miles. There's "no way" that 6qts/5000 miles (which is what you've observed with your car) is acceptable. Even according to GM's own TSB which states (1qt/2000 miles is not acceptable). The customer service/order taker was just feeding you with BS!!!
Don't give up on this...
Old 04-01-2010, 06:02 PM
  #48
66L72
66L72's Avatar
Update
Oh well
just curious if it was Geoff Allen or someone working with him that contacted you.
I hope Geoff chimes in again.
Regardless the reply is not adequate and you need to persue it, hopefully with Geoff's help.
Old 04-01-2010, 06:22 PM
  #49
68sixspeed
68sixspeed's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Have you checked for your states lemon-law requirements? Some are pretty easy, 4 visits for the same problem etc.
Old 04-02-2010, 01:09 PM
  #50
GOLD72
GOLD72's Avatar
Received 1,106 Likes on 718 Posts
Update
I was contacted by GM customer service today and informed that my 1 quart per 1000 miles is considered normal consumption on my C6Z06..........
What a load of crap!! GM was re-ringing LS1 and LS6 engines 8 and 9 years ago at that consumption level. Keep fighting.
Old 04-10-2010, 11:37 PM
  #51
NuVetteC6
8th Gear
NuVetteC6's Avatar
This is true... I was one of the ones that got thier C5 re-ringed - and they didn't do it willingly. Had to build a case as was afforementioned. I blasted GM for thier "uneducated consumer" form response letter and eventually got results. Car was 2001 C5 coupe.
Old 05-10-2017, 09:18 AM
  #52
usctroj836
usctroj836's Avatar
Default 2009 ZO6 56,000 mils
I drive aggressively and run through 1 quart of mobile 1 5w 30 a month at approx. 550 miles a month. Change oil religiously and check it weekly. On my 2nd gmpp major guard so the car is maintained at reliable checerolet in Richardson Texas. It is a great cat! I actually enjoy going to work!
Old 05-10-2017, 08:18 PM
  #53
Apocolipse
Apocolipse's Avatar
Received 1,284 Likes on 929 Posts
Run a lower noack rated oil.
Old 05-20-2017, 07:08 PM
  #54
oemtech
oemtech's Avatar
Went thru this same bull **** with GM & an RV chasis manufacturer (Workhorse) on 8.1L engine. Normal usage was 1qt to a tank of gas (75 gals). Well if do the math all need to do is change the filter and you will have already done an oil change. Even was told it could up 30k+ miles... Warranty was 3/36.
Bottom line... The hole is to big or the piston is to small. Rings not seating is bs on an RV engine as it very seldom goes sbove 4,000 rpm's.
GM is just covering their corporate ***.
Old 07-21-2018, 04:28 PM
  #55
usctroj836
usctroj836's Avatar
Default 2009 Z with 65k Miles purchased new.
I have 2008 C6Z06. Commuter with 21K miles. (Have the C5 T1 car to kick around) I noticed it was consuming 1 qt per 1000 miles which is much more than any corvette, or for that matter, any other car I have owned.
So started an "oil consumption" process with my local dealer. Well after doing this for the last 5K or so miles and it consuming 6+ quarts, I was told yesterday that:
According to GM document #2222953, normal oil consumption for high performance engine LS7 is 1 qt per 500 miles and that GM DVM Ray Moffat advised that this is normal oil use.
Very disappointing to say the least.
Anyone else experiencing this type of oil consumption and does this sound reasonable?
I drive aggressive. I love the acceleration with sticky tires. I go quick. Not fast except once a week I get to 90 or 100 as fast as I can. I use about a quart of Mobil 1 5W30 every 4 tanks or about a quart every 1,000. This is consistent. No smoke. No leaks.
Quick Reply: [Z06] GM document for normal oil consumption ridiculous
