[Z06] Aviaid Dry Sump Insert
Good info, sounds like that catch can is doing its job.
I have to empty mine every 1.5-2K miles. My thought is that because I am running the Katech oil pump with everything else stock (for a 2008), more oil is getting churned and atomized into the PCV system. My belief was that the Aviaid tank insert would reduce or eliminate it. Even with the catch can installed, when I removed the intake manifold to locate the damaged lifter, there was oil beading around the intake ports on the heads. That could explain the oil consumption problem I've been having. We shall see.
I also have the KaTech Oil pump, (blue printed version), and the LPE large tank with the baffle and the oil pan kit with the gates, and I get almost nothing in the catch can.
