C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Engine code - running lean. need help
Old Apr 23, 2010 | 03:23 PM
logan1080's Avatar
logan1080
Default Engine code - running lean. need help
When I am driving down the highway at 75mph in 6th gear the engine is not reving hardly at all, this will send the fuel trims to over 20% and set off an engine code saying its running lean in both banks. This seems to only happen when I am driving at low rpms in 6th. The car is bone stock except mild to wild. The dealer has checked vaccum lines, oil level and flushed injectors. The car only has about 7500 miles on it. Anyone know what could be causing this.
Old Apr 23, 2010 | 04:17 PM
fivefingerdeathpunch's Avatar
Default intake
do you have the stock intake still i had the same problem but i have a after market intake and was getting unmetered air past the MAF at the coupler in front it MFA i was running lean on one bank and rich on the other i change the coupler
Old Apr 23, 2010 | 07:35 PM
logan1080's Avatar
logan1080
Stock intake. Dealer did the injector flush and it did nothing for it. They blew out the MAF sensor and they thought that might have fixed it, we will see.
Old Apr 24, 2010 | 12:40 AM
carnutsx2's Avatar
carnutsx2
I had to spray out the MAF with cleaner twice with 7 or 8 long sprays each time. .
To Engine code - running lean. need help
