[ZR1] Lingenfelter parts on my ZR1...
Well I did the lingenfelter 710 kit on my ZR1.
Package Includes:
- Lingenfelter cast aluminum supercharger front cover assembly
- 2.60 inch diameter steel supercharger 10 bolt drive pulley - powder coated black - 11 rib
- 100 mm aluminum double bearing idler assembly
- Lingenfelter LS9 solid supercharger isolator coupling
- Lingenfelter ZR1 air intake system
- Increased boost level 12 - 13 psi
- custom tuning
- High Capacity Heat Exchanger
- Kooks coated 2" headers to 3" collectors and 3" magnaflow exhaust.
Well even with it 101 degrees outside the car is a beast. So much fun. So much for launch control cause at this point it cant handle it. I had Gwatney chevrolet in Jacksonville(became a lingenfelter dealer) install it and they did an outstanding job. They said the parts went on very easy except the headers were a pain to match up with the exhaust. I will be dyno in a few weeks. The stock dyno was 528 rwhp and 510rwtq. I hope to be over 600 rwhp and at this point I am 100% happy with the car. Runs great day to day and when you put it to the floor it gets sideways but not crazy. Right now with heat and humidity really high It breaks loose at 50.. bet winter time will be fun. I will keep you updated when I dyno it.
Package Includes:
- custom tuning
Congrats!
Guessing the hope for 600rwhp is modest correct? I thought pullied/LT ZR1's were easily surpassing 600 to the tire. More in the mid 600 range. Maybe I'm misinformed. Either way, sounds like a bad a$$ ride.
1 Post
Package Includes:
- custom tuning
Package Includes:
- custom tuning
I look forward to your dyno #s to see what the exhaust mods added over mine.
2" pn 66026602-2ex I also got mine coated to help with heat. They are brand new for ZR1s from kooks! These guys at this dealership are on there game with new stuff for ZR1. If you want call james at 501-982-0102 great guy.
