[Z06] need some help here. thanks!
07 z06, 10000 miles. everytime i start the car i can hear water running,or some fluid running. goes away once engine warms up. dealer has evaluated and flushed the cooling system without effect. service manager now says he cannot hear it anymore, but i can!
anhy suggestions?
anhy suggestions?
i hear fluids sloshing alot....when I push my car out of the garage for a wash, and it goes over the "lip" of the garage floor, I hear fluids sloshing all over ....almost like there are several gallons of water stored in my front fender.
But when starting it, i dont really notice it. You may just be hearing the windshield fluid, clutch fluid, brake fluid etc...moving around????
not sure. Im sure someone with more knowledge of the car will step in and offer better advice.
water gurgling through the heater assy inside the car? Try setting the cllimate control to one thing or another- to see if it makes a difference?
Premium Supporting Vendor
You could be hearing water sloshing in the HVAC case. There is a condensation drain on the firewall to evacuate this water, but sometimes those get plugged with debris.
My car makes this noise but only in the morning. I think is the water running threw the heater lines.
Could it be a simple as people are just hearing fuel slosh around? I guess if the car is off, and you are pushing it you are not going to hear a fuel pump or anything, but what about gas?
Yes, C6s have those too. That is what I was referring to. As far as I know all GM cars have them. Maybe all cars in general. You have to get the condensation out somehow.
...........same here, but this water "running" that I hear is prior to ANY movement. The car is sitting still on a flat drive, in neutral.
Every one of mine has made this sound. Don't worry.........it's like the "ticking sound of the lifters" that some of us Z06 owners hear, normal........
i feel better knowing im not the only one, however the sound is definitely fluid travelling through a pipe of sorts, not sloshing. no gurgling or bubbling sounds like air either.
its like the car has an enlarged prostate and has to pee a little every morning! (even though she is a girl)!
Get some headers and a Fusion exhaust and keep the valves open. The noise goes away immediately.
