C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Z06-specific radar hardwiring question
Old 11-01-2010, 04:36 AM
Fireblade
Fireblade's Avatar
Default Z06-specific radar hardwiring question
Have done a lot of searching through old posts because I was sure this would be answered, but it looks like most everyone is just using Invisicord, something I don't want to do, for a few reasons I won't get into...
I've wired V1's in the past on both a C5 Z06 and a C6 coupe by running the wire up inside the headliner, over to the passenger A-pillar, then down to the fusebox (seat heater fuse in the C6 coupe). In the C6 Z06, it seems the headliner is extremely tight up against the window, there's really no room at all to push a cord in. Has anyone wired a C6 Z06 this way, and what did you have to do? Do I need to remove the A-pillar trim and the visors to get enough room between the headliner and window to get the cord in?
Old 11-01-2010, 05:39 AM
spdmn75
spdmn75's Avatar
pull the a pillar and visor. it will tuck in farther and you can zip tie it to the wiring already in there
Old 11-01-2010, 06:56 AM
jlutherva
jlutherva's Avatar
Or just buy the Invisacord. It plugs into the connector on the back of the mirror.
Jim
Old 11-01-2010, 07:36 AM
BearZ06
BearZ06's Avatar
Received 1,414 Likes on 814 Posts
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
That's exactly how I did mine and I didn't remove anything. It should be like your C6.
Old 11-01-2010, 07:42 AM
GOLD72
GOLD72's Avatar
Received 1,148 Likes on 739 Posts
What I did five years ago.
Old 11-01-2010, 07:47 AM
Burnin4
Burnin4's Avatar
Jim
Bingo!
Old 11-01-2010, 03:10 PM
Fireblade
Fireblade's Avatar
It is somewhat different from the C6 coupe, the coupe has a hard plastic "headliner" with plenty of gap between it and the window to push a cord up into. But the Z06 has a fabric headliner that is shoved up tight against the window.
Old 11-01-2010, 03:30 PM
dmuellenberg
dmuellenberg's Avatar
Jim
Originally Posted by Burnin4
Bingo!
Not helpful guys - OP specifically said he didn't want to use the Invisicord.
Old 11-01-2010, 04:29 PM
Landru
Landru's Avatar
Received 1,054 Likes on 826 Posts
Why I'd agree with a couple others who recommended removing the a pillar, can't be that big of a deal.
Old 11-01-2010, 04:32 PM
Fireblade
Fireblade's Avatar
Yeah, I've removed headliners entirely before (in the C5), so it shouldn't be a problem. Thought I might be missing something, but sounds like that's the way to go and that it should work.
Old 11-01-2010, 06:03 PM
u1arunit
u1arunit's Avatar
Invisicord here as well!
Old 11-02-2010, 07:46 AM
jlutherva
jlutherva's Avatar
Your right...I'll have to blame that response on my short attention span and my reduced reading comprehension:o
Jim
To Z06-specific radar hardwiring question
Quick Reply: [Z06] Z06-specific radar hardwiring question
