C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] front end alignment problem
Old 11-28-2010, 01:00 PM
1962 corvette
1962 corvette's Avatar
Default front end alignment problem
I have 20,000 miles on my 07' ZO6 - time for tires - rear cooked and front with tread outboard and down to thread inside.
I will have alignment checked with new tires (PS2s) But am interested in the wear pattern on fronts. Anyone else have a similiar experience?
thoughts on what to look at when alignement time?
Bill
Old 11-28-2010, 06:24 PM
50 4Ever
Wil Cooksey #256
Support Corvetteforum!
50 4Ever's Avatar
What you are seeing is normal for the stock alignment. you might want to reduce the negative camber a bit.
Old 11-28-2010, 08:25 PM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
This will keep you in the ballpark of where your needs are...
http://www.pfadtracing.com/blog/wp-content/uploads/2010/01/corvette-alignment.pdf
Old 11-28-2010, 08:42 PM
GMuffley
GMuffley's Avatar
Exactly; the factory alignment is somewhat aggressive for street driving.
Old 11-29-2010, 10:41 PM
1962 corvette
Default Thanks
Bill
Old 11-29-2010, 10:56 PM
jimman
jimman's Avatar
I set mine at zero camber but still with time and sagging suspension it goes negative and still wears the insides. As far as handling, just fine with no issues for the street.
Old 11-30-2010, 12:34 AM
383vett
383vett's Avatar
Received 1,543 Likes on 1,043 Posts
If you got 20,000 miles from your original tires, leave the alignment alone. It's perfect!
Old 01-08-2011, 10:47 PM
rohard
rohard's Avatar
OK, I see the PFADT recomendations above, but they didn't say what the stock setting's are. I have an 08 ZO6. Back tires gone at around 12K, replaced with GY OEM's assuming I would get 25 to 30K from fronts and then buy a set of 4PS2's. At 17K, I am into the cords in the inside 1.5" on both OEM front tires, about 4/32" on outside. Just ordered PS2 ZP's for the front, will replace the back when they go down. I do not track car, looking for no handling prolems and resonable life. (got 30K on C5 fronts with factory alignment).
Is Performance Street (in PFADT above) what I am looking for, or is there another recomendation. How far is that from GM recomendations, and will I have trouble getting a dealer to deviate from GM recomendations? Doug?????
Old 01-08-2011, 10:59 PM
RicK T
RicK T's Avatar
Here's the factory spec chart. Z06 is the FE4 line:
Just FYI, the regular C6 owners who want tire life over max handling are taking the Camber down to -.1 to -.2 and getting better front tire life. Just sayin'. Good luck.
Old 01-09-2011, 01:15 PM
rohard
rohard's Avatar
Thank you, will talk to Dealer Monday.
Update: Dealer said no problem, set front to -.4 (As found was -1.3 and -0.9) Camber as a compromise. As always, this forum is a very useful source of information for those of us that just enjoy the cars, and not as much into the mechical knowlege as others are. I thank you.
BTW, what has happened to tire prices? I paid $858.65 for 2 P325/30R19 EMT's, out the door (Sales tax, core, ect inc) GY OEM's in March. Current price is $1029.38 out the door, 20% increase in 9 months. Wow, and the Michelin's are even more.
To front end alignment problem
Quick Reply: [Z06] front end alignment problem
