[Z06] Complete LED Int/Ext Kits ^^^50% Off^^^ Just $69.99!!
C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
I would recommend the kit as the lighting is INCREDIBLE now! That said, since the LEDs don't put out much heat at all, I'm not too concerned with the fitment. The LED lights do still fits inside the rear side markers, but they make DIRECT CONTACT with the inside of the lens....
None of the other lights were a problem, EXCEPT for those two rear side markers. They are pressed ALL THE WAY IN, and yet still make contact with the inside of the lens. I don't feel like I missed anything....
May have received a pair slightly larger than the others. Not normally a problem however...
Hey i purchased these a while ago... wondering if there is a pdf of some sort for the install.... especially for the map lights, reverse and license plate light....
Should have came with the kit. If not PM me for a copy!
Just put me in today. I have the Centennial wth RED Jake mats and RED interior lights. Since car has RED accents. The outside has is same as posted by OP. Trik to get good pic for me was a tri-pod with no flash.
