[ZR1] Lowered ZR1 Pictures ?
#41
Night Owl for life
Received 3,247 Likes
#44
anyone confirm or deny if this is mandatory?
#45
Lowered on factory bolts. I had mine aligned afterwards and the only adjustment was made to the right rear, other than that it was still spot on and the tech told me it was a very small adjustment!!
#50
those are not from Apsis, those are the factory parts. I ordered a roll of CF and put that on there myself. I took the piece off of the car, cleaned it very good then put the CF on there allowing it to extend beyond the edge. I then took a very sharp razor knife and trimmed it. After that I put a couple of coats of clear over the top and it has been on there a couple of years now!! Very easy to do and I have a lot of people asking where I got it. I also did the same to the pieces in front of the rear tires!
#51
Wow, the result is fantastic!!!
One more question, if I may ask: what brand is that roll of CF?
#52
it's 3M. I bought it from MetroStyling.com. You can by it by the roll there as much or as little as you want. Works good and has lasted a long time. I get a lot of questions about it from people that see the car in person.
#53
Thanks a lot for your reply!
#54
It appears to be metrorestyling, and I found it: http://www.metrorestyling.com/Carbon...-Wrap-s/25.htm.
#55
#57
Sorry thread Hi-jack...!!
But do you go all way down front and rear?
Because I want to do this mod tomorrow when my car will be on the lift for the wheels swap.
thanks
thanks
#58
Attachment 47763076
Attachment 47763077
Attachment 47763081
Attachment 47763077
Attachment 47763081
