[Z06] Long time lurker zo6 Question
Hello every one this is my first post! I'm unfortunately in a position where I have to start looking for a new car. My current car is a 2002 Camaro SS A4 with 95000 miles on it. The car is starting to show signs of a problem that I'm not willing to sink money into.
My former car was a 99 SS m6, it was a fun car (old LS1.com days) that was great on 1st gear throttle jabs and rowin' thru the gears with drag radials. Even though my best time was 13.36@ 107 compared to my A4's 12.98@ 106. The m6 was doggy of the line and near impossible to get a good consistant launch from a stop it was either chirp and bog or just spin the tires. Maybe torque management was at fault.
Ok,my question ....... Is the zo6 due to its light weight and 427 really easy to get off the line without bogging or slipping the clutch too much to make it a pain to drive in stop and go parking lot situations? I have seen a vid of a German guy go 0-150 in 4th gear but it seems like driving like that is abusive to the bottom end and clutch and should not be the norm.
I'm thinking a GS with an A6 would be the best of both worlds but I'm not crazy about the gills and from lurking I have seen too many guys end up loosing their butt on a trade because the lure of the zo6 was too much to deny.I want to do it right the first time.
What do you guys think?
Thanks,Chris
Thanks,Chris
Received 4,565 Likes
2016 C2 of Year
2015 C3 of Year Finalist
My Z06 does not bog nor do I need to ride the clutch for easy starts in first gear. The clutch engages and the car goes effortlessly. Plenty of low end torque. Go for the Z and you will have no regrets, believe me
Thanks,Chris
Thanks,Chris
I tell people that the Z06 is so docile that that its easy to forget there is 505HP under the hood, UNTIL you press the loud pedel a bit hard.
Your granny could drive it and never have a clue how much power is there.
The Z06 like any manual transmission car will bog if not driven correctly. The fact is the Z06 will easily over power the stock rubber leaving you with the opposite problem, tons of wheel spin and even axle hop. Mine is a DD and is so smooth and easily driven you forget just how powerful this car is.
But throw in some DRs and driven properly a 100% OEM stock Z06 is an animal
http://forums.corvetteforum.com/c6-z...-129-50-a.html
Tom
Tom
Thanks,Chris
Thanks,Chris
Thanks,Chris
Thanks,Chris
I don't think i would ever take off from a dead stop in 4th. I regularly leave it in second when coming to a yield sign at 2 or 3 mph and accelerate away - too lazy to drop it down in first. it effortlessly pulls away no lurching, pinging. Its absolutely smooth.
I will also say with the fixed roof my 2009 z06 is as tight as a drum. no rattles or cowl shake. feels more secure with no rattles compared to a
c6 with the removable top.
My c4 zr1 even though i loved that thing rattled and buzzed like crazy with lots of cowl shake and really bad cowl shake with removable roof out.
Been caught in rush hour traffic on 100 degree days with AC on. My Z06 ran cool, and the clutch was light and easy. I could easily take off in first gear at idle with out pushing on the gas. A stock z06 is as docile as any car I have driven. But when you push hard on the loud pedal, watch out!!!!
I Agree with Mr Gizmo. Traffic jams are pretty rare where I drive, but I did discover, almost by accident, that you do not need to even touch the gas pedal in parking lot/stop and go situations. One less thing to worry about when you're already pissed off about the traffic.
are you simply talking "daily driving?" If so, the car is super easy to drive day to day. If you mean dragging and nailing killer 60 times, then yeah, it takes some practice to kill it in these cars.
It's inevitable once you test a Z06 you will want one. The car is simply to impressive not to want to buy it plain and simple and no other car on the planet in my opinion will match the performance for the dollars spent. If you were blindfolded and told you were in a wide open parking lot and just drive the car away you wouldn't know if you were in a Z06 or a Yukon Denali it is so nice and easy to drive.
Depends on what you want out of the car. I have owned a couple of M6 F-bodies and they are very tricky to launch. Don't expect anything less from the Z06 on the drag strip. If you want a drag car, the auto will be more consistent and might even turn in better times if you aren't good launching a manual (however I'm not real knowledgeable on what to expect from a C6 GS auto on the strip). The Z06 is just as streetable as an M6 F-body (except for ground clearance).
Ok so yesterday I was able to test drive a black 2011 3 lz with 25 miles on it. The car had been sitting so long the rear rotors were rusted to the pads and I stalled it as soon as I released the clutch breaking the rotors free.Keep in mind I haven't driven a manual tranny in about 9 years so it took a little getting used to at first. I was a little shocked at how far up the pedal went to engage the clutch, it was so high I was thinking I still had it in neutral.Overall it wasnt too bad,I think I would just have to get used to it all over again.As far as being docile and smooth it really was just like driving a normal car, very quiet and uneventful.
My time with the car was limited and you can only evaluate a small portion of what this car has to offer on public roads with a salesperson but I did give it full throttle roll on in first and a bit in second.I think traction control was on as it just barked the tires a bit and took off like hell without getting sideways.The engine was very smooth and spooled up quicker than anything I had ever driven, btw the zr1 exhaust sounds AWSOME.
The next car I need to drive is the Grand Sport with 2:73's and NPP.
Chris
Chris
Chris
Chris
I have no illusions of my car being better or faster than a base c6 its just I keep my cars a long time and for this kind of money I need to be happy with everything and make the right choice.
Just a demonstration, Chris. The LS-7 has enormous torque; in fact, the German should've kept going all the way to 198.
But you're correct, driving a Z06 around in 5th would certainly be 'abusive'.
