C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] busted by laser...
Old 04-07-2011, 10:25 AM
383vett
383vett's Avatar
Received 1,546 Likes on 1,045 Posts
Originally Posted by C5 Frank
One more thing you guys may not realize as well.... Every new car with LED taillights will set off your Laser detector when they hit the brakes in front of you and are at just the right (wrong) angle.... even the laser distance monitoring systems on some of the high end cars will set it off too. Makes for a lot of false warnings... Nothing worse than a false Laser warning!!!
Not true. I have had a Laser Interceptor for one year. It has saved me once from a motorcycle lidar while going 75. I have never heard it go off other than testing before this incident. Where did you get your information regarding false signals from LED taillights? The monitoring systems for Audis and BMWs use a radar signal, not laser.
Old 04-07-2011, 10:30 AM
dsevo
dsevo's Avatar
On that interceptor website it says that the heads have to be visible. Are there any hidden solutions available? I don't like the idea of some random black box showing on the front and rear of my Z.
Old 04-07-2011, 10:33 AM
0spoiled996
Former Vendor
spoiled996's Avatar
St. Jude Donor '12
i have the 9500CI and it does shift the laser and has saved me from a 1/2 dozen tickets where I could actually see the cop on the bike shooting it at me and I was speeding. FWIW
Old 04-07-2011, 10:44 AM
TBIRD57
TBIRD57's Avatar
Default watch
on/off ramps and the bridge
buttress supports for them
bring back the CB!
Old 04-07-2011, 11:01 AM
screaminchevy
screaminchevy's Avatar
Originally Posted by morris
There is no complete radar laser solution....
Valentine and passport both detect laser neither will jam it. You have to buy a standalone jammer system for complete coverage. For complete coverage you will also want to select a jammer with front and rear heads. Installation is critical for good protection
yeah there is. The passport 9500ci IS a complete system. and the only one out there to my knoweldge.
Old 04-07-2011, 12:23 PM
morris
morris's Avatar
yes the heads must be visible.
As far as the shifter setup, to each his own, I dont mean to get into a mines is better than yours thing. But I will say that any perspective buyer should check out the guysoflidar website where there has been intensive and comprehensive testing of all the Jammers we have discussed and draw your on conclusions.
Old 04-07-2011, 02:27 PM
Turbooo2u
Turbooo2u's Avatar
Where did you mount in the front? In the black grill area?
Old 04-07-2011, 02:32 PM
nzk
nzk's Avatar
ok guys im leaning towards the interceptor, the videos of the product are pretty solid. anyone have any install pics?
i got zapped on 121 northbound between alma and stacy by allen PD. drove by there today and there was a police truck at the same spot with constant on radar. V1 was all over that one. someone had already been pulled over on the southbound side.
Old 04-07-2011, 02:48 PM
0spoiled996
Former Vendor
spoiled996's Avatar
St. Jude Donor '12
Correct and the rear above the license plate but below my back up camera.
Old 04-07-2011, 03:40 PM
383vett
383vett's Avatar
This picture was taken with the camera 2' off the floor. Normally, the sensors are pretty much hidden because they are set back by the grill.
Old 04-07-2011, 04:31 PM
0Adam at RSI
Former Vendor
Adam at RSI's Avatar
I must ad that the V1 now can be integrated with the HUD, that feature alone makes me want the V1 but the V1 by its self can't compare to the 9500 CI. Of course it can't compare because of cost and features...
I drove: Dallas > DC and Dallas > San Diego.
On the DC trip, I used a 8500i (which is comparable to the V1) and it was flawless as it treated me well for 4 years.
On the San Diego trip, I used a V1 and it had more false alarms and did work well but at the end of the day, I have my faith in the Escort.
This is a huge debate between my local car buddies, most of them do use the V1 BTW.
The V1 with shifters is a great package but if you want the next step, get the 9500CI!
The install is sweet on the 9500ci, my hand sits on the control panel and the display is on the left side of my rear view mirror. I also installed the "Alert" light in my drivers side A-pillar air vent so it glows red to green at night, also great for 2 sensory inputs!
Old 04-07-2011, 04:59 PM
laxman420
3rd Gear
laxman420's Avatar
i run a blinder M47 on my car. Its fantastic. Install is easy and the results are great. got hit today doing 70 in a 55. the leo looked confused. remember to JTK (Jam to Kill).
Old 04-07-2011, 05:53 PM
  #33
mach1pannu
mach1pannu's Avatar
Good info in this thread...The only thing I am wondering is, what happens when you are speeding and the police know it? Is there an excessive speed or some sort of endangerment ticket that they can tag you with if they don't clock the exact mph? I'm sure they would still pursue or at least from my experiences...
Old 04-07-2011, 06:08 PM
  #34
C5 Frank
C5 Frank's Avatar
I have had mine go off 17 times in a row when following a bus with LED taillights.... Everytime it hit the brakes my V1laser went off.... Also has happened to me when behind a A8.... There was also an article about some new cars going to laser for distance warning anyhow it might effect laser detectors.
Old 04-07-2011, 06:17 PM
  #35
383vett
383vett's Avatar
Interesting, the Lidar Interceptor has very specific directions about mounting the device absolutely level around license plate height and directly ahead. Your V1 sensor I assume is mounted at windshield height and probably more sensitive to taillights. The only time I get a false warning is on first startup if I am up against a wall. Then the park assist feature comes into affect for the first 5 seconds after startup.
Old 04-07-2011, 06:18 PM
  #36
mcar00
mcar00's Avatar
V1 and Laser Intercepter (front only) works for me.
Old 04-07-2011, 06:27 PM
  #37
morris
morris's Avatar
have you had your V1 software updated? That might help quite a bit.
To busted by laser...
Old 04-07-2011, 07:24 PM
  #38
joe11204
Procharged F1X 7.18 @ 197
Support Corvetteforum!
joe11204's Avatar
St. Jude Donor '09-'10-'11
Do you have a LI? In the software setting for my LI you can select DO NOT WARN for Unknown Gun.
That will solve most of the false alarms.
In my car I have a LI Quad HP, a V1 and Passport 9500XI. Yes overkill but it works for me.
By far the V1 has the most false laser alerts.
Old 04-07-2011, 07:48 PM
  #39
augydog
augydog's Avatar
St. Jude Donor '08-'09
Same thing happened with me with my V1. Especially true with the new Infinity's and MB's.
Old 04-07-2011, 08:10 PM
  #40
bass mechanic
bass mechanic's Avatar
that is untrue, ive been behind several cars with LED tails and no issues.
i have had false alerts while going through the shadows of trees of fence lines where passing shadows causes a light pulsing effect across my sensor. however despite the false warning (which is RARE) does it hurt to slow down anyway?
Quick Reply: [Z06] busted by laser...
