[Z06] my 2007 Z06 engine has not blown up yet
I'm convinced the ones that are babied blow up. Mine sees the track every month even when its over 100*. Has over 77K miles in 3 years now. It gets me to work and back every day on the original battery. I go thru a lot of rotors, pads, tires and change the oil according to the DIC. It sees 7K RPM every day.
I warm it up to 140* before taking it over 3k RPM and keep the oil at the full mark.
I do not miss shifts and over rev.
I'm going to keep doing everything the same. When my warranty expires I may put in a new set of OEM springs
DH
DH
My 09 engine blew while it was parked in the garage and I just looked at it funny.
Is this normal?
Is this normal?
DH
DH
Lol... I think LS7s hate the owners who drive it like a VOLT and it gets fed up and blows up. If you drive like it's meant to be.... They are happy and last a long time!!!
That should be a hint to you garage queen owners... Please enjoy it.. Not garage it!!
Think about it.. If you have a hot blonde.. And not take care of her like a man should.. What will happen? She will leave you!! If u only do all the right things... Then she will be with u for life!!
These type threads have come up before.
http://forums.corvetteforum.com/c6-z...-blown-up.html
But they never get the post counts that the opposite type threads get.
On a side note, it appears that at least one guy posting in that thread that his motor had not popped, jinxed himself and has since posting up in that thread, lost a motor.
Just a heads up.
Just a heads up.
Just a heads up.
Just a heads up.
My stock motor 09 Z06 is running fine at 14K miles. The Goodyear RFT's were corded and replaced by NT-05's, 295/335. I'll keep the engine/drivetrain stock with fresh stock fluids while it is on warranty.
