C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] What did I do NOW??? Please Help.....Leaking water?
Old 06-03-2011, 06:13 PM
Geared
Support Corvetteforum!
Geared's Avatar
Default What did I do NOW??? Please Help.....Leaking water?
So I used my A/c for the first time in a while today, and i also had the car in the air.
I got home and popped the hood (always do this to help extract heat from the engine bay after a long drive) and I noticed alot of condensation on a metal pipe leading towards the fire wall, and also heard dripping on the header.
I got under the car and a pipe was "misting" and dripping water fairly rapidly. This was after I shut the car off, but its possible it was happening while driving.
It appears to have subsided, but the "misting" seemed odd, almost like one of the pipes has a small crack in it....
If this is normal, ok....but if not....
Question is.....if I dont use the A/C can I drive the car??? It appears to be 100% water.
Old 06-03-2011, 06:15 PM
Liquid1
Liquid1's Avatar
I have also heard a sound as if water is being dripped onto a sizzling hot pan after shutting off the car. I haven't yet investigated this issue and found an answer as to whether this is normal, so I will also be following this thread.
Old 06-03-2011, 06:35 PM
blackmagicZ
blackmagicZ's Avatar
Most likely, just condensation. Mine dose it every time it's hot outside and the AC comes on. No problems yet.
2008 Z
Old 06-03-2011, 06:38 PM
04 YelloW Z06
04 YelloW Z06's Avatar
I live in miami so its very hot down here, thus my A/C NEVER turns off lol only sometimes at night or when im going to be going WOT. I have yet to hear a sizzling noise coming from my car after i turn it off. My Z is a 2008 btw.
Old 06-03-2011, 06:44 PM
RichieRichZ06
Supporting Vendor
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
It will do that and if it's humid outside, it will be worse then normal.
Old 06-03-2011, 06:57 PM
Geared
Geared's Avatar
ok.....what about the misting.....like it literally looked as if someone was spraying some quick detail out from under there lol
Old 06-03-2011, 07:01 PM
z06clif
z06clif's Avatar
my car does it all the time. Also a stream of water heading down the driveway. ..............normal condensation
Clif
Old 06-03-2011, 07:06 PM
Geared
Geared's Avatar
thanks for all the replies. i can get on with the weekend now! cheers
Old 06-03-2011, 07:12 PM
seamus2154
seamus2154's Avatar
That's normal. I'm surprised no one else noticed this on their car. They all do it. I feel it's a poor design and should be draining away from the exhaust but GM knows better.
Old 06-03-2011, 11:19 PM
dean23
dean23's Avatar
Normal on any vehicle with ac. When the ac is in use the evaporator core gets very cold....... 32-34 F when this happens the air being pushed through it has moisture in it, it collects on the evaporator and turns to ice or frost...... then when vehicle is shut off the refrigerant stops circulating and the evaporator warms up..... so just like the outside of your frosted beer mug it starts to melt..... this water ends up in the bottom of the heater box and by design is directed to the drain.... out it comes and drips down from the drain tube to the ground or header etc. the more humidity in the air, the more pronounced this will be. the condensation on the 2 lines and accumulator is normal as well.
Old 06-04-2011, 12:10 AM
tim414
tim414's Avatar
St. Jude Donor '12
I live in North Texas where it's usual for high humidity conditions. My 2010 Z06 does this dam near every time i park it after having driven it with A/C on. There will also be a puddy of water underneath where it's parked. The same thing will happen w/my Yukon.
The sizzling you hear is NORMAL too. It's the condensation off the cold side of A/C hose (humidity condensating on the cold hose) collecting and dripping down onto the hot exhaust pipes.
I've been hearing the sizzle ever since I brought my 'Z home new last year.
Tim
Old 06-04-2011, 12:47 AM
lemans
lemans's Avatar
completely normal, not a thing to worry about
Old 06-04-2011, 07:45 AM
u1arunit
u1arunit's Avatar
Yep!
Old 06-04-2011, 11:01 AM
Landru
Landru's Avatar
Received 1,047 Likes on 821 Posts
Exactly.
Scares the bejebbers outa new Z06 owners as evidenced by their many posts on the topic.
Old 06-08-2011, 12:47 PM
Chevy Cust Svc
Chevy Cust Svc's Avatar
I agree with the above, this is normal.
Good luck out there.
Brent
GM Customer Service
Old 06-08-2011, 02:44 PM
bearphoto
bearphoto's Avatar
SoCal Events Coordinator
St. Jude Donor '12
Normal, all cars with a/c do this. does not damage anything and is very brief after shutoff.
i usually turn the a/c off about a mile or so from shutoff so its done by the time i park it. anyway, no problems, all a/c cars do this.
Old 06-08-2011, 03:59 PM
BigMike NY
BigMike NY's Avatar
Yep normal here too! I've owned my Z for almost a month and a half now and was very concerned the first time I heard the "tssssss" "tsssssss" sound. Then I discovered it was just condensation from the air conditioner...
Old 09-03-2012, 04:00 AM
haseeb
haseeb's Avatar
im facing the same problem ,i have re checked it again and again , does any 1 of u see the water driping out when we r driving the car ?
i see the drips all the time when the ac is running and it finishes as soo as i shut down the ac .
just wanted to know that does it drip only when u shut the car off or its drips all the time when ac is runing ..
Old 09-03-2012, 05:19 AM
tim414
tim414's Avatar
St. Jude Donor '12
Simple terms....
There is NOTHING WRONG with your cars a/c system. It's a refrigerated system. It chills the air from either inside the cabin or it pulls outside air in and cools it before it enters the cabin. This depends on how you have it set. Recirculate is cooled air from the cabin, cooled and back into cabin. The yellow light on the control unit will light when set this way. Sometimes if it's very hot outside/inside the car, it will stay on recirculate (yellow light) unitil the cabin cools down.
The mositure in the air (humidity) chills and collects inside a close unit that has coils and it pulls the hot/humid air across it, where it collects moisture from the air and drips down onto a pan basically and drains out of the unit/car. Also, the cold line from compressor running to this 'air cooler unit' will collect moisture and it will drip down onto exhaust sometimes. There is NOTHING WRONG with your a/c unit or Z06..
To What did I do NOW??? Please Help.....Leaking water?
Quick Reply: [Z06] What did I do NOW??? Please Help.....Leaking water?
