[Z06] Replace X-pipe with strait pipes?
I'm running AR headers with hi-flo cats and X-pipe but I'm still not happy with the sound. Can the x-pipe be replaced by strait pipes to get a better sound? Anyone try this? My local muffler guy can do it. Thanx.
if you can let us know what kind of sound you are looking for, we could help more... X-pipes give a V8 a more exotic sound usually. two straight pipes will make it sound old school, while the h-pipe will smooth out that same sound a little bit.
Thanx for the input. I'm looking for a LOUDER sound when the flaps are open. And the car sounds a little like a UPS truck with the flaps open now. I'm not crazy about that. Trying to avoid a cat-back exhaust since I don't think they're worth it.
http://www.youtube.com/watch?v=up37CkQcExM
Then this is with a cam added:
http://www.youtube.com/watch?v=JIofK...eature=related
Changing from an X or an H to two straight pipes will only change the tone slightly and will not raise the noise level.
Have you tried the Z06 muffler mod? It caps the perforated pipe inside the muffler and makes the open side louder. Although it does have a tractor sound to it, it is cheap and fairly easy.
Then change mufflers. Straight pipes will give you that fresh from the fields farm truck sound............. Don't waste your money or ruin the car for that matter. I put ZR1 mufflers on my car and it became quit a bit and pleasantly, louder.
Where did you get ZR1 mufflers and were they expensive?
Im pretty sure there is a performance gain when using an X pipe over an H or straight pipes. Something about equalizing exhaust pressure.... Mustang guys will remember changing their stock H pipes to X pipes.
You will lose HP if you remove the x-pipe. The primary reason it is there is to feed a secondary pulse from the opposite bank to assist scavenging. ARH is one of the few that put it in the optimum position (right after the merge collectors)
Try replacing the cats with an off road no cat X then do the muffler mods. This is what I have and it sounds like a stock car. Your muffler guys should be able to do this. Quiets down the the flaps closed through the mild to wild bu. Very aggressive sound with the flaps opened. Should be relatively inexpensive for a much better sound.
Keep in mind, LS engines use a slightly different firing order than 60's Chevy engines, so you're never going to get the same old school sound, no matter what you do to the modern cars exhaust system.
