C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Figure out how to hook the exhaust switch up to the steering wheel controls.
Good idea, but I don't think the existing wiring will reach and I don't think I have the talent to execute it properly.
I think the solution for me is to find one of those 08+ 'replicas' with the CF-ish trim that has the 'Tombstone' built in, cut a hole, then move the switch over to that one.
Anyone have any ideas about the steering wheels? The new wheel looks stunning.
Hey rich, how much for the steering wheel only and steering wheel with airbag and cover but no emblem?
Steering wheel only is $245 shipped. The airbag comes with the emblem so there is no way to get a blank center unless you remove the emblem. The airbag is only an additional $181, but the shipping is a little extra because it's considered hazardous.
[QUOTE=RichieRichZ06;1578641946]The 2012 Centennial Edition interior parts are now available from GM. This kit includes the steering wheel, airbag/cover, center console lid, shift boot and the e-brake boot. The pieces are the upgraded leather bits that are seen in the following pic.
how much for the COMPLETE kit in blue, Everything in the picture???
If the shifter is 2007 and prior the hole does not line up, it's lower than the newer ones. I removed my shifter and drilled/tapped the hole in the correct location for the ****. Or you could get the newer shifter from Rich as well.
