[Z06] Crap! I painted my Z06 mufflers, now they smell of paint after a drive!!
A few months back, I bought a set of Z06 mufflers with the mod already done. I took them in to my dads shop, removed all paint with industrial grade paint remover, sanded the **** out of them, primed them and finally, applied 550 degree high temp black and silver spray paint. I let them bake in the booth for a little bit and that was that. They came out amazing. Here are the pics:
The problem now is, after a drive, or if I'm stopped at a red light with the windows down, I smell paint. The underside of the mufflers is starting to burn away the paint. What did I do wrong? Should I have used a higher temp paint? If so, what degree? I made this post so others wouldn't make the same mistake...now I have to do it all again.
Did you use high temp paint? If so it might not be burning off but just heating up for the first few times and that can cause a smell. If you used standard paint it might burn off. Either way it either will or it will not. If it is actually the primer burning then over time the top coat will be burned as well.
I used high temp paint good for 550 degrees F. The mufflers have been on there for about 300 miles. Noticed the burning smell the day I drove it home after the install.
Time for a set of Fusions.
Better yet a set of akrapovic.....muffler mod is like porsche boxster....we all know what kind of porsche that is....... A .... Mans porsche......fill in the blanks in the middle....lol
Well I took a look again today, it seems the black paint is chipping off around where the straight through pipes are welded on. No paint is chipping so to speak on the cans...just burning off. I'm hoping that after enough driving, it'll all be chipped/burned off and hopefully won't smell anymore...or I'll buy new mufflers. It's just too much work to get these off and on this car.
