[ZR1] First Oil Change For ZR1
Are you guys following the computerized oil life for the first oil change? I have read/heard that the first oil change should be earlier to remove particles that may have accumulated during the engine's first 1000 miles or so.
Adam
Adam
Changed ours yesterday ....
- total miles 12630,
- 7388 miles on oil/season,
- OLM 25%,
- 45.1 mph ave,
- very little "fuzz" on the drain magnet (much less than Z06 ever had)
- used 1/2 qt during the year.
Now sleeping for the long winter
- OLM 25%,
- 45.1 mph ave,
@ 500 to 1500 miles is always a good time for a first oil change on any new engine. After that, just follow the oil life light.
I agree with the exception of never going over 5000 miles on a oil change. Also, I think it really depends on how you drive it and what kind of driving you're doing. If you're on the track a lot then you should obviously change it sooner. If you push on it at least one or two times every time you get in it like me then you should probably change the oil every 3 to 5000 miles. I wouldn't always trust the computer about changing the oil. Their has been problems with the oil life computer making the car go to many miles before signaling a oil change is needed. You pay to much for a car like this not to take extra precaution by doing frequent oil changes. I just wouldn't push the boudaries of oil life on these cars. I did my first change at 850 miles mainly because the oil in my car was already 1-1/2 years old ( brand new )when I got it.
Received 8,928 Likes
The OLM is very accurate and GM has been selling cars with them since 97. I use the OLM all the time. My Tahoe gets around 6K miles per oil change with dyno oil, my Malibu gets around 8K miles and the Vettes get changed once per year. I sent samples of the oil from my 03Z to Blackstone Labs for analysis when I changed the oil at the end of a year. This was with 12 track days on the car, quite a few autocrosses and just normal driving that added up to about 5K miles. The OLM read 35% and the oil analysis showed the oil was still good and there was no abnormal wear occurring in the engine. You don't need to go overboard on the oil changes even when the engine is new. I keep my cars at least 6 years and the Tahoe is 9 years old at the end of the year so don't want to be paying for engine repairs that I could avoid. So far the OLM has been trustworthy for me.
Bill
Bill
It's a matter of opinion and I have done first changes at 500 to 1000 miles on past cars. But most recently I have waited to the first 5k on the 06Z, CTS Wagon and 2011 ZR1 to do the first changes. The OLM allows 7500 miles for me on the 06Z and ZR1 and 10k on the CTS. So that is what I am following on subsequent changes after the first. I use AMSOIL ASL in all cars so I know the oil is good for well past 0% on the OLM. Your results might vary.
I do mine (not a ZR1) every year or 3000 miles. I would go 5000 miles MAX between oil changes.
Now our BMW 335i gets it every 15000. Now that it is out of warranty and I am doing it myself (BMW paid for it under warranty) I will do it every 7500. I am actually kicking myself for not doing it at 7500 between their changes since new but they swear it is not needed. Car still runs like new at 65000 miles.
Bill
Bill
Tim
Change the oil on my D13 at every 50,000 miles or about every five months. Fifteen years ago the oil change interval on this engine was 10,500 miles.
Run my ZO6 Vette from spring to fall including eight to ten track days, about 8,500 total miles. Am about finished driving for this year and intend to change all drive line lub prior to putting the car away and heading to FL. The DIC indicates 46% life left. Using Red Line 5W40.
Tim's engine may last longer than Bill's but, imo, it won't necessarly be because of the difference in oil change interval.
My Vett's OM says change oil when the OLM reaches zero or every year. Thats good enough for me. I don't, however, as a matter of course, run it all the way to zero. Nowhere does the om mention mileage. My 05 Envoy's om says the same thing. Tim, on the other hand, believes engine oil should be changed based on mileage. And that is a ok. Its a free country, at least for the time being, so if he wants change his oil every so many miles it's his choice. As I wrote earlier, in addition to eng. oil, will change gearbox and rear end lube prior to putting my car away for the winter. Nowhere does the manual say to do this. So in our own way Bill, Tim and my are pretty much the same.
Thanks for the replies
I guess its mostly a matter of personal preference
I have a 2011 with only 1000 miles but the car is a year old
Computer displays shows 85 percent oil life remaining, guess I'm wondering if I should change the oil as the car is a year old
_"SCOTT"_
Once a year is a good rule of thumb...
Don't waste you money changing the oil more than once a year or when the DIC is near 0%.
I've alway changed the oil in my 02 Z06 and 2009 ZR1 and always take an oil sample and send it in to Blackstone Labs for analysis. The oil is still perferct at 0%. I have run both cars on the track the Z06 mostly and the only comment was the the Chromimum count was slightly elevated which made sense running it high RPM on the track.
Lifetime NCM Member #2497
