[ZR1] zr1 tire rotation
Maybe you need to go MILK MORE COWs .... your response added NO VALUE ...
OOP's.. now I have one that added no value!
They show on the sidewall which side should be "out", but they are not directional, so they can roll in either direction.
Butt.....after you swap them, your DIC display of pressures will be off.
The pressures will display okay, it's just that if the DIC says "Right Rear 22 psi" it will actually be talking about the Left Rear.
You can either reprogram the tire pressure sensors, or just be aware that the indication of side is backwards.
Bob
