[Z06] Transmission gear change?
I know that there are no 3.90 differential gears for the C6 Z06, but could a gear change in the TR6060 transmission equate to a 3.90 in the differential? Has anyone done this? Is it possible?
The gear ratios used in the Z51/GS transmissions would be very close in 1st, 2nd and 3rd. In fourth the ratios in both transmissions are the same, 1:1, so no gain.
I combined the new ratios in a RPM L-5 TR6060 with an equally modded L-5 ZR1 diff for a bullet-proof drivetrain. When a certain other Canadian did the same trans ratio mod he picked up 3 tenths so I suspect he too figure there was a "gain" to be had
Cheers, Paul.
