[Z06] c6 z06 need info or opinon on oil canister losing oil
Hi Guy's,
Well i had my car now since 2008, i do my oil change since i had the car... Now i know by experience wen you check the oil on dip stick there is 3 mark's or should i say 3 hole's bottom middle and top, now i know for a fack that this car you have to start it and let run to running tempurature then wait 5 min then check oil level because it is a dry sump and has to pressurise the system... but i know for a fack wen car is warm and wait 5 min level should be at top hole or top mark... wen cold the oil should be between the lower mark and middle mark...
NOW my question i did a cam swap last week did everything by spec's i had to lower oil pan for oil pump instalation also i change the 2 seal's on the 2 hose coming from the oil sump canister that go's to the oil pan...
Now i have a problem i start my engine oil pressure is perfect and i shut car off wait 5 min and check oil and everything is were it should be at top hole on dip stick... the nex day check oil level and the oil is at the middle hole on dip stik... did not start the car that day... i waited a extra day check oil again and NO MORE OIL ON STICK... It never did that before...
Were is the oil going back to the oil pan... not a good sign i dont want to start it dry i have no leek's and the other thing was wondering if there is some kind of check valve that would stop the oil from going back to the pan... now probably if i started the car everything would pressurise back up and the oil level would be good.... but my question is y do's it started doing this since i install my cam... there is nothing i did to prevent this and just dont like what i am seing...
If anybody can help me i would appreciated.
Thanks Jeff
Thanks Jeff
You are only capable of checking the oil properly for about 20 mins after running the car up to temp. It's normal for it to drain out of the dry sump. That's why there are 2 drain plugs.
Doing a cold reading does not give a valid reading.
OP, check it again after you get the oil up to 175*, 5 min. after shutdown.
yess i agree that that is the best way of checking it to have accurate reading but my question is do's anybody ever check there oil cold and do's it read anything on dip stick or nothing....
Thanks Jeff
Thanks Jeff
I am confident that a 175* reading would be at the middle hole, which is where I run it so as not to be over the top on track days with 250* oil. (my 09Z holds 10 1/2 Quarts, earlier models were 8 to 8 1/2 quarts and they probably want to run full on the track.)
I never check mine cold as it is a waste of time. And I always check it at the same temp 180-190* and always 5 minutes exactly after shut down.
And (not picking on you )
There = Their
Fack = Fact
Do's = Does
Please don't look for mistakes in my posts. You won't find any *** I am perfect
DH
There = Their
Fack = Fact
Do's = Does
DH
There = Their
Fack = Fact
Do's = Does
DH
There = Their
Fack = Fact
Do's = Does
DH
Mine hasn't been driven since Tuesday. I just checked the dipstick and cold, the level is below the lowest (3rd) hole by about the same spacing as the holes, so yes it has drained down well below "normal".
