[Z06] Window Indexing Issue
Neither the driver or passenger side windows will index when either door is closed.
When I close either door, after getting inside, the window stays down, i.e., does not go all the way up and seal. To close the window completely, I must flip the window switch in the door.
When I open the door, from the inside, the window indexes downward, but does not go back up when the door is closed.
How can if fix this?
Thanks for your help in advance.
Power Window Initialize
After a power reconnect such as battery replacement, the window index‐up feature will not function until the system is initialized.
Once power is restored:
1. Close the door.
2. Raise the window and hold the switch up for three seconds after the window is closed.
3. Release the switch, then hold the switch up again for three seconds and release.
1. Close the door.
Owner's manual? What's that?
