C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] OEM Air Filter Question
Old 04-28-2012, 07:52 PM
Dirty Howie
Dirty Howie's Avatar
Default OEM Air Filter Question
I bought a stock filter but it has a manufacture date of 2005 (clean one). It is different at one end than the 2008 filter (dirty one). They are both the same at the other end.
Looks like the filament ends on the 2005 are open not closed like the 2008.
Question is: Will the 2005 restrict air flow compared to the 2008 ??
Side by side
2008
2005
Both same at other end
DH
Old 05-03-2012, 12:18 AM
Dirty Howie
Anybody ........... ?????
Old 05-03-2012, 04:24 AM
MarkRx
MarkRx's Avatar
here ya go... don't get too wrapped up in the drama, it's a 3 year old post
http://forums.corvetteforum.com/c6-t...same-pics.html
Old 05-03-2012, 09:59 AM
Dirty Howie
Thanks, I'll check it out.
DH
Old 05-03-2012, 04:39 PM
Dirty Howie
So according to your pictures the one with the open filiment ends is th LS7 and I'm running around with a LS3 in my car
DH
Old 05-03-2012, 08:30 PM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,543 Likes on 2,618 Posts
DH
I've got the LS9 air filter element (PN 25940997) and had no installation problems. The Z picked up 4MPH in the MM last October over my April run (173.5 vs 169.4).
The changes in the car in between: NT-05's replaced OEM tires, Coleman lightweight two-piece front rotors, EE PCV catch can and the LS9 air filter.
Old 05-03-2012, 08:55 PM
whatcop?
whatcop?'s Avatar
Location: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
You guys really just need to get a K&N filter. I popped the one out of my ZR1 which was still brand new and threw in a K&N. Definitely could feel a little difference.
Old 05-03-2012, 10:00 PM
AzDave47
AzDave47's Avatar
Some of us would just as soon not have oil going into the intake. That is one of the reasons I got an EE PSV system catch can, too. The ZR-1 filter flows more air than the stock engine can use (good to 800+HP).
Old 05-03-2012, 10:40 PM
whatcop?
whatcop?'s Avatar
I don't know who came up with that figure but that cannot be right.
1 CFM = 28.328 l / min
So the stock ZR1 filter is figured at 850 CFM.
850 x 28.328 = 24,078.8 liters/min
Take the 24,078.8 and divide it by 7.0 liters. This will give you 3,439.82. That is the rpm at which your filter lost efficiency if your motor was actually gulping up 7 liters per revolution.
Shoot lets say we are only capable of using half of our motors. So take 24,078.8/3.5 = 6,879.65 rpms would be the inefficiency point.
The stock 90mm throttle body will flow 1170 CFM. The K&N flows 1100 CFM. Sooooooooo you do the math.
Old 05-03-2012, 10:47 PM
Dirty Howie
Why don't you sell me your ZR1 at a good price
DH
Old 05-03-2012, 10:49 PM
Dirty Howie
So know one can tell me which filter pictured above is better to use ??
DH
Old 05-03-2012, 10:54 PM
AzDave47
AzDave47's Avatar
Not sure where you came up with the 850CFM for the ZR1, but Katech did the development work on the ZR1 filter with Donaldson and determined it will support 800+HP which is way above what our Z06's make. I think I'll take Katech's research over your math.
Old 05-03-2012, 10:56 PM
AzDave47
AzDave47's Avatar
DH
I don't know how much air the LS3 filter flows, but the LS9 filter flows 38% more air than the LS7 filter per Katech's R&D with Donaldson.
Old 05-03-2012, 11:06 PM
whatcop?
whatcop?'s Avatar
http://forums.corvetteforum.com/c6-z...e-ls7-ais.html
Old 05-03-2012, 11:08 PM
whatcop?
whatcop?'s Avatar
http://www.corvettels7.com/Halltech%...Comparison.pdf
Old 05-04-2012, 12:37 AM
Dirty Howie
Did they make C6Z06 filters in 2005 ???
DH
Old 05-04-2012, 12:44 AM
Dirty Howie
http://i714.photobucket.com/albums/w...rx/filters.jpg
Dave does the one on the left look like your LS9 filter. Does the middle one look like your old LS7 filter.
Doesn't look like the LS9 is the same size as LS7 and why the black grating ???
DH
To OEM Air Filter Question
Old 05-04-2012, 12:49 AM
AzDave47
AzDave47's Avatar
OK, from this we know what the pressure drop is at 850CFM for the LS7 and LS9 air filters. Do you know what the pressure drop was on the K&N when they said it flowed 1100CFM? The LS7 and LS9 filters would flow 1100 CFM given enough pressure drop.
Old 05-04-2012, 01:25 AM
Minkster
Minkster's Avatar
DH
Early '06 C6Zs were available for sale in the fall of 2005.
Old 05-04-2012, 02:22 AM
Dirty Howie
Thanks Rich
WSIR this Saturday
DH
Quick Reply: [Z06] OEM Air Filter Question
