C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Ride quallity of the DRM Bilstein shocks??
Old 11-02-2012, 07:02 PM
CGGS
CGGS's Avatar
Default Ride quallity of the DRM Bilstein shocks??
How do the DRM shocks compare as far as ride quality.
I added the JOC shocks and while they do tame the rear-end, they make the car ride more harsh at times.
I am wanting the ride quality of the stock shocks, just with better body and rear-end control.
Also on the market are QA-1 adjustable shocks.
Old 11-02-2012, 07:38 PM
OliverM5
OliverM5's Avatar
Are you lowered?
Old 11-02-2012, 07:41 PM
CGGS
CGGS's Avatar
Originally Posted by OliverM5
Are you lowered?
No, stock height
Old 11-02-2012, 07:44 PM
AreOhBeeC6Z
AreOhBeeC6Z's Avatar
I love the ride quality, I would say it rode similar to stock and absorbed bumps much better. The wheels don't feel like they are all going in different directions when going over a bump. I dig them!
Old 11-02-2012, 08:04 PM
OliverM5
OliverM5's Avatar
Originally Posted by CGGS
No, stock height
My car is lowered and the DRM bilsteins feel solid, no rough ride. I put a set of them on every vette I buy.
Old 11-02-2012, 08:11 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
I didn't notice much of a change in ride quality going to DRM shocks, I did notice that wheelhop was much improved.
Old 11-02-2012, 09:59 PM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Less dive and body roll as well.
Old 11-02-2012, 10:25 PM
OEFastZ06
OEFastZ06's Avatar
I replaced the JOC shocks with the DRM. The DRM shocks give you a better ride and keep the car planted. The JOC give you a harsher ride.
Old 11-02-2012, 10:51 PM
okiedude
okiedude's Avatar
Installed my new DRM's last Thursday, drove about 100 miles on them at the track on Sunday, they ere fantastic. Today was my first day really driving them on the street (of Oklahoma City), ride quality was like night and day from the stock shocks. The stockers only had about 12K miles on them, but after putting the DRM's on, the old shocks might as well have had 112K miles on them. Our roads really suck and everything just smoothed right out. Best $450 you can spend.
Old 11-02-2012, 11:47 PM
CGGS
CGGS's Avatar
That sir is exactly what I needed to hear.
Very rare that you find someone who has tried both.
Thanks so much for chiming in.
Old 11-02-2012, 11:54 PM
Shark Racer
If you'd like to go for a ride in mine we can probably set something up.
Old 11-03-2012, 12:03 AM
AzDave47
AzDave47's Avatar
Received 4,532 Likes on 2,610 Posts
I run the standard Bilstein Sports and the ride is better than stock and the rear control is much better. I'd get the DRM Bilsteins now if I needed new shocks.
Old 11-03-2012, 12:17 AM
PCMusicGuy
PCMusicGuy's Avatar
I had 75k miles on the originals and replaced them with DRM. Definitely smoother on large bumps at speed. Definitely more jarring with large bumps at very slow speeds.
Old 11-03-2012, 01:02 AM
tim414
tim414's Avatar
St. Jude Donor '12
I have not noticed that. I have noticed the biggest difference is the car seems to roll over the bump instead of hopping over the bump. Feels more controled to me.
I did not notice the ride to be any different over stock.
Old 11-03-2012, 01:52 AM
Les
Les's Avatar
That's a good way of describing it. It's hard to determine much difference in ride quality but especially the rear tires are much more settled over bumps instead of wanting to skip. The way the whole car sets into a turn is also much better.
Old 11-03-2012, 01:58 AM
VetteVinnie
VetteVinnie's Avatar
Received 1,723 Likes on 1,096 Posts
Love my DRM Bilsteins! I plan to add some sway bars to complete the handling at some point.
It took a couple of years and trial and error, but I am finally getting the car I wanted when I first started modding. Had it out again tonight, and this is by far the most fun I have ever had behind the wheel of a car.
Old 11-03-2012, 02:36 AM
CGGS
CGGS's Avatar
That would be awesome, yeah I definitely would like to. Then we can compare back to back the JOC shocks vs the DRM.
What does your weekend look like?
I would like to get the DRM's while there is still stock on them from Doug.
To Ride quallity of the DRM Bilstein shocks??
Old 11-03-2012, 11:17 AM
GMuffley
GMuffley's Avatar
I think the ride quality with the DRMs is better than stock--not to mention the better handling.
Old 11-03-2012, 08:17 PM
CGGS
CGGS's Avatar
I want to give a big thanks to Shark Racer for the ride in his Z w/ DRM Bilsteins.
From my perspective the DRM's offer a more plush ride (more refined) over small jarring bumps compared to the JOC shocks and about the same dampening on the larger bumps, while both tame the rear end of the car.
For a daily driver, the DRM's are definitely the way to go.
I will be doing a swap here in the near future.
As for the sway bars, I am not sure what I am going to do yet. The JOC sways and/or end links are making a hell of a racket in the front with the car back at stock ride height.
I found that in the middle setting they are way too prone to understeer and IMO ruins the turn-in and aggressiveness of the Z06, and in the stiffest setting, the balance is pretty good, but not at the expense of all the noise that it is making.
Shark Racer's car with stock sway bars and DRM shocks handled awesome and that might be they way I end up going.
Old 11-03-2012, 10:45 PM
Shark Racer
I think you'll be able to fix the sways, it's pretty easy to get those bushings off and either grease or strip. When my back has recovered from today we can do it at my house if you want. (is your car lowered?)
Quick Reply: [Z06] Ride quallity of the DRM Bilstein shocks??
