C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 06 Recall
Old 12-07-2012, 04:15 PM
Z06-HEC*
Z06-HEC*'s Avatar
Default 06 Recall
Had no clue there was a roof recall for the 06 until someone mentioned it in someone elses new purchase post here.
I called GM and they checked and mine, that i bought used, has not been serviced for any recalls.
I called the local dealer and they said they only change it if it needs to be. As far as i can tell my roof is fine, no noise or rattles no sign of it being loose at all.
I hit 142mph recently on the highway ( before learning of this recall ) and it was perfectly fine through bumps, dips and turns.
Is this a mandatory change or is it only if it needs to be?
Anyone done this recall already?
Old 12-07-2012, 05:07 PM
Mr. Gizmo
Mr. Gizmo's Avatar
That is BS the dealer is telling you. It was a recall. GM is obligated to replace these roofs. What ---will they only change it after it blows off.??The potential of the roof blowing of is dangerous and can cause property damage or bodily injury.
Old 12-08-2012, 07:02 AM
capevettes
Support Corvetteforum!
capevettes's Avatar
Received 4,553 Likes on 2,160 Posts
2016 C2 of Year
2015 C3 of Year Finalist
That is one recall that definitely should be done on the 06. Mine had been done on my 06 before I bought it. Many documented incidents of the roof flying off. Make sure your dealer knows what they are doing.
Old 12-08-2012, 09:03 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Tell the dealer to put that in writing, then when it flies off, hits a motorcyclist and kills them, they can handle the liability.
They need to replace it ASAP.
Old 12-08-2012, 09:21 AM
tim414
tim414's Avatar
St. Jude Donor '12
Old 12-08-2012, 09:36 AM
Canuck
Canuck's Avatar
I have an '06 and after I heard about the recall I kept an eye on the roof for any signs of separation. I couldn't find any. Then, leaving a stop light one day, I heard what sounded like a backfire..... trying to figure out how that could happen under acceleration, I glanced in the rear view mirror and could see a guy in a van picking up something from the road. He followed me to a restaurant and asked me if I was missing something. I never even noticed the roof panel missing as it doesn't show from inside. Geez.... how to feel stupid... So obviously, it doesn't require high speed to remove it.
GM fixed it and aside from some of the rubber being folded all is good.
Old 12-08-2012, 12:22 PM
Prime Target
Prime Target's Avatar
Location: Murrells Inlet, SC (formally New Windsor, NY)
When you realize the panel is delaminating, it will probably be to late. Don't take the chance of thinking it won't happen. It will. If the dealer is that uninformed, then he isn't the one you want doing the repair.
Old 12-08-2012, 12:58 PM
VetteVinnie
VetteVinnie's Avatar
Received 1,680 Likes on 1,070 Posts
Not just the Z06. The roof on my 2006 coupe popped AFTER it was supposedly fixed by the dealer. I only took it in as a preventative measure. I never had it on the car (bought the car new - always ran the transparent top). It de-laminated on the way home and ~80 MPH. They had to replace the whole roof after that.
Old 12-08-2012, 04:15 PM
99HRDTP
99HRDTP's Avatar
If you do a search, you'll see why it's important to do the recall. Mine popped after 2 years. Plenty have been done. It's not a TSB, but a recall for a reason, despite what the dealer says.
Old 12-09-2012, 06:53 AM
KLLRVET
KLLRVET's Avatar
Find a dealer who wants to do it, don't use one that doesn't
Old 12-09-2012, 11:32 AM
briancb1
briancb1's Avatar
Dang, I better check on mine now! Thanks for bringing this up.
Old 12-09-2012, 11:39 AM
sublime1996525
sublime1996525's Avatar
Yep it's a recall and needs to be done.
Old 12-09-2012, 11:46 AM
Z11409
Z11409's Avatar
TSB number 08050859003E
Old 12-09-2012, 11:47 AM
RFE-57
RFE-57's Avatar
Originally Posted by tim414
Had mine done already......07'
Old 12-09-2012, 11:56 AM
Vette5.5
Vette5.5's Avatar
I got some GM recall notices on my 06's roof panel but did nothing about it, as looked fine. One day at the gas station, noticed the back corner lifting, so was dealer time. They ordered a new panel, and installed it next week. I'd make sure to get yours replaced.
Old 04-02-2014, 06:21 AM
Z06 Steve
Z06 Steve's Avatar
noticed the rear corners on mine are lifting as well recall time! how long is this recall good for?
Old 04-02-2014, 09:21 AM
crAzy
crAzy's Avatar
I checked this when I got my car and the 1st owner had the recall done. 3rd owner here and all is good.
To 06 Recall
Old 04-02-2014, 10:54 AM
Bgreenard
Go Fast
Bgreenard's Avatar
l'm sure with all the bad press GM would be happy to replace the roof.
Old 04-02-2014, 11:03 AM
vvlf
vvlf's Avatar
Yup, that sounds like a GM Dealer Lol.
Old 04-02-2014, 11:26 AM
sublime1996525
It should still be good because your roof can still fly off and hit someone. Call a dealer.
Quick Reply: [Z06] 06 Recall
