C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] WCCH, heads, intake, untuned results...
Old 12-15-2012, 07:56 PM
jeffreystar
jeffreystar's Avatar
Default WCCH, heads, intake, untuned results...
Some of you know I swapped a set of WCCH LS7 Stage II heads onto my otherwise stock LS7 with AHR longtubes and KBII intake.
Having some issues with HP Tuners so I was unable to tune the car so this is just a base line pull the car was running fairly rich at WOT but I think it's about dead on.
Before the WCCH head install dyno numbers:
474 rwhp / 469 rwtq
After the WCCH head install dyno numbers with zero tuning:
505 rwhp / 480 rwtq
SAME DYNO.
30 rwhp gain and 20 rwtq AND my engine doesn't blow up when I rag on my car? I'll take it
On another note my stock motor'ed E85 powered Buick T-type with a TE60 Turbo and FMIC made:
485 rwhp / 568 rwtq on 31PSI Can't wait till I put the big motor/turbo combo in early next year!
Old 12-15-2012, 07:59 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
474 rwhp / 469 rwtq
505 rwhp / 480 rwtq
SAME DYNO.
Definitely a fringe benefit.
I went ahead and put you on the "PUP" list. (Physically Unable to Pop due to a broken stock exhaust valve) List
http://forums.corvetteforum.com/c6-z...st-valves.html
Old 12-16-2012, 05:28 AM
Turbosixx
Turbosixx's Avatar
Nice gains from WCCH!!
The "pup" list. That's great.
Old 12-16-2012, 07:00 AM
Rock36
Rock36's Avatar
How much were your heads milled?
I'm curious what gains, if any, are had on stock manifolds and intake with WCCH stage II heads. I have WCCH stage II heads on an otherwise completely stock motor, and I only had surface milling done on mine so I don't expect any significant change in my CR. I didn't notice any SOTP difference at all after installation. I will be doing a tune to take full advantage of the WCCH heads, of course I did the heads for post-warranty reasons more so than the performance.
Anyway nice gains.
Old 12-16-2012, 11:50 AM
jeffreystar
LOL, very funny and thank you!
Old 12-16-2012, 11:53 AM
jeffreystar
Anyway nice gains.
My WCCH were only milled .005 for clean-up so no increase in compression.
Old 12-16-2012, 12:04 PM
Z06Ronald
Z06Ronald's Avatar
Old 12-16-2012, 02:30 PM
superramvette2
superramvette2's Avatar
what kind of dyno? Dynojet or mustang?
Old 12-16-2012, 03:45 PM
jeffreystar
Just a plane jane Dynojet.
Old 12-16-2012, 05:10 PM
sublime1996525
sublime1996525's Avatar
Nice gains. How were the power power pickups under the curve?
Old 12-18-2012, 12:16 PM
jeffreystar
Funny you should ask...
I was able to drop by the shop and build a before/after dyno comparison and I've updated my DIY thread to show the dyno results.
CLICK HERE:
http://forums.corvetteforum.com/c6-z...-headswap.html
To WCCH, heads, intake, untuned results...
Quick Reply: [Z06] WCCH, heads, intake, untuned results...
