[Z06] Explain Cam specs
I think stock duration is 218/238. So the cam you are referring to has less duration than stock. Check lift, that must be with 1.7 ratio rockers. With 1.8 ratio the lift would be .644
Take the time to find out what YOU want. Then tell them what cam YOU want. Whose car and money is it . That kind of info would have me runnin for my car.
This is a cam they had custom grinded for a customer which backed out so they had it just lying around the shop. They were going to to give me a great deal if I choose to do that cam but I think I am going to go with a bigger costum cam.
LSA is lobe separation angle. Basically the distance in cam degrees between intake max lift and exhaust max lift(on the cam lobe) changes cam events(when valves are opened/closed), makes torque curve flatter or more "up and down" effects idle quality and more without getting too far in depth.
don't buy a cam that's been 'lying around the shop' regardless of price.
Lsa
Tighten (Smaller LSA)=lower end torque--more detonation--reduced idle vacuum --narrow power band. Widen( Larger LSA)=opposite effects
Anyway, OP the ls7 seems to prefer a larger split in duration, since the heads flow so well on the intake side. I'll be looking for around a 228/248 duration and .620" lift cam myself in a few years when I do heads/valves.
I do not like the duration split of that cam OP.... As mentioned by jbs, the LS7 needs more exhaust duration than intake. If you look at the specs of GM's aftermarket grinds for the LS7, you'll see a pattern that supports this.
Duration is the length of time in degrees of rotation that the valve will be open. Lift is how far open the valve will get. LSA is angle that is represented between exh and int peak lift and the cam's center.
